Question about Dual Electronics CECT P168 Cellular Phone
How to download to i9 phone
Can you show me how to download my pictures and music to my i9 phone from my computer?
  • Anonymous Jan 26, 2009
    same here
Cant connect to internet cant get mms settings can any one help me i have an i9 phone ty for your time
Posted on Jan 19, 2010
Connect your phone to a laptop or pc using the usb cable...the phone will then show threee options....choose mass storage. this will then setup the phone so that you can see the memory avaiable on the phone under mycomputer. there will be two drives associated with the phone...the internal memory and the memory card. when you browse the drives you will see various folders...copy the media to the related folders.....hope this helps
Posted on Feb 16, 2009
To Solution #3. Go to your phone book, click on the name of the contact you would like to set a ring tone to, click edit and scroll all the way to the bottom, below fax and underneath birthday. hope it works for you.
Posted on Mar 15, 2010
How do i set songs for ringtones on the i9 phone
Posted on Jan 25, 2010
    President:
  • Dual Master
  • 1,734 Answers
If you want do more than browsing between your files, e.g. synchronizing your Outlook contacts or calender, then you will need a PC sync suite. For the i9 or i68 phones you can find one at http://chinamanuals.com for download.
3 Suggested Answers
truenoae86jp
  • 44 Answers
SOURCE: cect i9 phone
Well let me start off by saying Cect makes knock off phones and in your case its a knock off Iphone.
They are imported phones from Hong Kong (i believe) and are made very cheap.
Most likely if your memory card is too big in size, lets say a 4gig Transflash, and they phone only supports up to a 2gig, well the reason is right there. Your memory card is too big and the phone wont support it.
If the memory card you are using came with the phone, most likely something has gone corrupt or there is a virus on a file you have uploaded or its missing the phones format on the card.
I would go in and first check to make sure the size is supported.
(check the manual or online where you bought it)
if it isnt, than thats your problem.
if it is, i would erase your files from the memory card and see if they phone will read it then. If it does, than one of your files is corrupt and just narrow it down with trial and error until you figure it out.
if you still cannot open the card,
i would search your phone in the settings and the menu until you find a memory card option or an option to format a memory card. Once you have found that, format the card (on your phone) and then go about placing your music and videos in the correct labeled folders.
I hope this helps
Posted on Feb 17, 2009
SOURCE: cannot download music to motorola i9 phone
multimedia- my music-menu-reload music
Posted on Aug 20, 2010
I have the i9 When I make a call to check me account I sometimes need to press 1 How do i get the keypad on screen after I make a call and how do I download pisc and music
To upload pictures to the phone:
connect the phone to your PC using the USB cable
If prompted: press the "mass storage" option
The telephone should show up as a hard drive on your PC
If you have an extra memory card in your phone, TWO hard drives will show up
1 is your phone, the other one is your memory card
Move the mp3 to a folder called My Music
If the folder is not there, create it
Move the video to a folder called Video
Move the jpg's to a folder called Photos
Jul 11, 2009 | Apple iPhone 3G Black Smartphone
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Is the Cect I9/I68 Mac compatible?
Yes, you can connect the phone as a mass storage device via USB or bluetooth. Maybe there is even a PC suite software. Ask at http://chinamanuals.com - they a least have one for Windows systems.
Mar 09, 2009 | Dual Electronics CECT P168 Cellular Phone
My computer does not recognise my CECT i9 phone
Youneed to plug in the phone to the computer while the computer is off. Leave it plugged in, then turn on your computer. This will load the drivers from the phone needed for the computer to recognize it....
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Putting music on phone
when you hook your i9 up to the computer you should see something pop up saying that your phone is connected open up that file then you should be able to drag music into it its good to download limewire or frostwire they both give you free music downloads
Jan 09, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 downloads
For music i use and LOVE Blubster..go to www.blubster.com select the free download--have never had a problem and always find all the songs i want..and its FREE..download the music to your computer then plug the USB cord to the phone to the computer and it should pop up the files..save them to your music file in device F(your memory card)--device G is the phones memory and if you put them there it will tell you the file is to large..
For videos and music videos..my favorite and FREE site is http://www.mv3gp.com/ I love that site..
3gp is the format all cell phones use for video..so if you need more google free 3gp videos and more sites will pop up..But these are just the TWO i use personally and LOVE.. for the videos same as music drag the file to the F device in your video files..Voila..
Then you can find them in your phone under your documents icon and under memory card..or in your multimedia icon and audio or video player
Nov 14, 2008 | Dual Electronics CECT P168 Cellular Phone
Cect I9
how can I download music and videos on my i9 phone
Oct 30, 2008 | Cell Phones
Download
I had a look at one of those phones and they are not to bad, Little feature bare but not bad all the same.
Here's a forum with all the help you need for the CECT P168
Lot of people experiencing similar issues with the Iphone Clone
http://p168.forumotion.com/
Aug 26, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
1,503 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
