Question about Bosch WFK 2401
Bosch WFK 2401 hot water wont shut off even if you turn power off
All
  • Don Bickle Jr
    Don Bickle Jr Jan 07, 2009
    Sorry, I'm new to the forum and didn't fully know how to do 1st post. My problem is: When you try to do a load, the hot water will not shut off, even if you turn the power off. You have to turn it off at the wall to get it to stop. Is there a seperate fill valve for just the hot water? Looking for any help I can get. Thanks!
  • Don Bickle Jr
    Yes
  • 242 Answers
I can help , If the unit is leeting water in with the power off the only thing it can be is the water inlet valve , it is the componet you connect your water line to under the unit behind the front lower panel. Tell me if you have any other questions and let me know how this works out.
Phil
Posted on Jan 07, 2009
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Will not start on some wash programs, such as 40 or 60 fast spin, but will work when 40 woolens program selected, and other delicate programs too.
Check that the hot water tap is on or if the valve filter is blocked. If both these are ok, it may need a new hot water valve.
Hope this helps.
Use link item 171295 on page 4
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFK2401UC%2f01&ESHOPTYPE=S
Aug 21, 2010 | Bosch WFK 2401
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
Jul 21, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Sep 08, 2009 | Bosch WFK 2401
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
WFK 2401
Replace hot water valve.
Aug 13, 2008 | Bosch WFK 2401
WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
262-893-4840
Apr 23, 2008 | Bosch WFK 2401
Washing Machines Logo
120 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
