Question about Hotpoint 18 in. DC28 Slim-Line Built-in Dishwasher
Diplomat dishwasher intermittent beeping
Part way through wash cycle there is an intermittent bleeping noise, when you open the door the rinse light is on and the machine has stopped mid cycle. Nothing I do rectifies this problem. Any ideas welcome.
5 Suggested Answers
  • 3 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Posted on Aug 25, 2007
  • 7 Answers
SOURCE: Dishwasher stops inbetween rinse and dry
hi
if the problem faults within the first 1 minute the first check the connections on the main module behind the control panel,as you you look at the control panel there is a pink connection to the left,if this looks like it has got hot then theres yopur problem(you will find that the joint on the board has come loose from the soldered joint,module requires replacing.
if this connection looks ok then the heater is open curcuit and will require replacing.
Posted on May 18, 2008
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: Dishwasher; Diplomat 8322. Set it to wash on any
Apparently there is a sensor above the normal water level where it drains. The water level rises above the sensor if the filter is full of gunge and the water cannot drain properly. The sensor is activated and stops the cycle. You have to remove the filter mesh, clean it, drain out the excess water (I did this with a turkey baster!) and replace the filter. Then everything works again!
Posted on Dec 18, 2009
Diplomat dishwasher
It is likely the door switch is faulty and not letting the dishwasher start the cycle. Need to have the full model number and make of dishwasher to advise further.
Apr 11, 2014 | Dishwashers
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
ADL348 is constantly beeping and does not complete cycle
If it beeps continuous and starts on the rinse cycle,then this is indicating the control board is bad and needs to be replaced. NOT THE TOUCH PAD, but the control board.
Dec 17, 2013 | Dishwashers
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
Why does my Diplomat ADP 8902 dishwasher beep twice when i switch it on and the 4th wash program light flash and do nothing else?
Can I say thank you for the above advice. Hit the programme button 4 times and closed machine. Now running rinse cycle. Let hope it works afterwards. Will post ant let you know.
Nov 20, 2010 | Dishwashers
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Dishwasher; Diplomat 8322. Set it to wash on any temperature but after a minute it defaults to rinse and bleeps constantly
Dec 17, 2009 | Dishwashers
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
I have a a whirlpool dishwasher ADG7440
hold down the on button for 5secs it will reset
Jun 24, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Hotpoint 18 in. DC28 Slim-Line Built-in Dishwasher Logo
309 people viewed this question
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
bosch5
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
