Question about Pioneer PRO-119 60" Rear Projection Television
Television Fade After about 4-6 hours of use the pictures fades away. Sometimes after a few days it will start working again, sometimes longer. I am curious as to what I need to do to fix it.
  • Pioneer Master
  • 8,617 Answers
What model set do you have. I can no doubt help but need the model number.
Posted on Jan 14, 2008
I have an RCA HD52W59 TV that will turn on and picture is fine for awhile, then it will fade to total black. Still has sound and does not power off. Nothing will show on screen, not even menu options....
Thats a deflection problem which is causing the CRTs to shut down during deflection loss. The deflection board will need replacement. You can get replacement deflection boards from www.tvrepairworld.com
Apr 23, 2011 | RCA HD52W59 HDTV Projection Television
RCA TV fades to black
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Jul 01, 2017 | RCA Televison & Video
The lcd tv (lg 42LG5000) which is now about 15 months old has developed a fault which is intermittent some times when first switched on sometimes after half an hour an hour the left side of the screen...
The backlight inverter is dropping out, on the older lgs the backlight inverter is separate from the power supply, if this is the case you can only obtain it with a new panel.
otherwise the newer lgs have the inverter built on the power supply.
in this case you can replace the entire power board.
May 20, 2010 | Televison & Video
PICTURE TURNS BLUE THEN FADE AWAY TO BLACK SCREEN.
The most common issue with these model of Sony CRT rear projection TV's is faulty CRT's. the blue was the most common of them to fail. If that is the case then you are unfortunately out of luck as the CRT's are no longer available. there is a possibility of finding a service technician who can remove the faulty CRT and have it sent away to have it rebuilt. The problem is eventually the remaining 2 will do the same thing at some point. Take a few moments to rate my answer... Thank you. : )
Nov 17, 2009 | Sony KP-57WV600 57" Rear Projection...
PICTURE SUDDENLY DARKENED AND IS FADING AFTER 4 DAYS
you may have just put it into fade out. find thee fade out control and reverse it the mode. hope that works.
DFD
Apr 11, 2009 | Televison & Video
Panasonic PT-47WX49E
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
Sep 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
