Question about Motorola Mobility RAZR V3xx Cellular Phone
Even though I am writing a regular text, it sends them Multimedia
I have NO attachments, no signatures and my phone keeps sending my texts as multimedia messages. It doesn't start off as one, but changes to one when I send it. WHY?
Message center number is wronk
Posted on Jan 08, 2009
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • Dec 02, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
    How to add signature on text messages
    There isnt an exact way to add a signature at the end of the txt. In order to do so, you have to create a template with your signature, then insert the template at the end of your txt. However, know that it will count towards the 160 character limit. Instruction from the user manual (pg 38-39) below. Hope it helps!
    Message templates
    When you often use the same phrases, you can save the message under template messages. Adding the message as a template
    1. Press Menu > Messaging > Templates.
    2. Press Options > Add New.
    3. Write the frequently used message > Options > Save.
    Sending a message with template
    2. Select the message to send.
    3. Edit the message > Options > Send.
    note: You can add a template while writing message. Write a message > Options > Add Template. Choose Text or Multimedia and select the message to add.
    Mar 08, 2011 | Pantech Cell Phones
    How do I email pictures taken
    You should be able to send a text message with the picture attached to an email address.
    to send a multimedia message/text message w. picture attached:
    -find the actual picture you want to send on your phone and select it
    -then hit your "menu" or "options" button, which should give you an option to send/share the picture
    -select text message or multimedia message (MMS)
    -in the "to" line for the text message, enter the email address you'd like to send it to
    -hit "send"
    Hope this helps!
    May 28, 2010 | Nokia 1680 Phone Unlocked FREE 1GB
    Can you save a text template to be put on your texts every time
    Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
    Mar 28, 2010 | Samsung Propel A767 Cell Phone
    When sending TEXT Messages it gives error multimediat message settings not defined
    you must select the option new text message to write and send text message...here u have selected the multimedia message sending option...for sending multimedia messages,u must have the settings from the service provider..u can obtain it from the service provider by contacting their customer care..
    Oct 21, 2009 | Nokia 2760 Cellular Phone
    Texts changing to a multimedia msg
    Unfortunatly there is no EASY way to fix this Problem. The only thing that you can do really is to Upgrade your Cellular Package and Add Multimedia Unlimited-This should help with this Situation though!
    Dec 29, 2008 | Motorola Mobility RAZR V3
    Automatic signature?
    the RAZRs wont add a signature, even if u put one in. i have the same problem on mine.  Ill c wat I can do, but idk if i can get it 2 work.  A nice fone 2 get wud b a samsung,  THANKS 4 RATING
    Feb 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
    Text Signature
    Dear MissyT, there is an option in your handset under text settings. There you can go into signature, edit it and write your signature and then send the message. I hope you'll be able to attach your signature with it.
    If that has helped you please help 'fixya'
    Nov 16, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
    Phone Sending MMS Messages as Default
    The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
    Oct 02, 2007 | Motorola Mobility RAZR V3m Cellular Phone
    Motorola Mobility RAZR V3xx Cellular Phone Logo
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
