there is no e10 error code it shouls flasx\h a sequence like E4 then 10 Both numbers are needed to diagnosethere is no e10 error code it shouls flasx\h a sequence like E4 then 10 Both numbers are needed to diagnose
the little wrench means it has shut down because it has exceeded the maintenance count, probably for the cleaner web in the fusing unit. Call service at 1 800 243 5556
Error 26 is referred the explorer can be in favor heavy of dirt, which causes that it does not have the suitable speed of return.Clean and you lubricate the zones of work of the to explorer.
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Hello sir; the error code # you given is invalid please double check again.
