Detergent leak from washing machine
I have a front load machine and recently while washing clothes i saw detergent was leakinh from below............please suggest a solution to this and why it might have occured??
  • smorrissey1 Mar 08, 2009
    Sometimes the He liquid detergent that I use leaks from underneath the detergent dispenser of my Maytag Epic front load washer. I am very frugal in the amount of detergent I use, and there doesn't seem to be any apparent trigger for leaking. My husband checked the level and the machine is leveled. Any ideas?
  • 679 Answers
It seems problem of excessive detergent, try running a cycle with less detergent and then let me know, if the problem persists.
Thanks for using FixYa.
Posted on Jan 07, 2009
    Problem Solver:
  • 4 Answers
I had the same problem and mine had a rubber gasket when u open the door..it had a hole in it caused by the bleach eating at it. I got a intertube patch kit and put it on the hole till I got one ordered from home depot or lowes.
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
Tip
Washing Machine Detergent
There are many questions about the type and the amount of washing machine detergent that is needed. Whether you are using a top loading washing machine or a front loading washing machine it does make a difference as to what and how much detergent to use.
Generally speaking a front loader washing machine will need to have less detergent then a top loader washing machine. Combine this with the water savings of the front load washing machine and you will get a substantial savings. However the front loading washer may be much more sensitive to many detergents. The recommendation of many manufacturers is to use HE detergent. This is designed to give less suds then many other detergents.
This is true but the use if the special detergent is not necessary. With the front loading washer you can decrease the amount of detergent used and still get great results. With warmer water you also can get better cleaning from less detergent. If you want you can also mix your fabric softener with the detergent and the fabric softener will keep the suds down for you.
If you have a top loading washer then you may want to experiment with using less detergent then you have thought would work in the past. By using warm of hot water you also can reduce the amount of detergent used and get great results.
Today’s high efficiency washers are very effective clothes washing machines. You can wash clothes with far less detergent in these efficient cleaning machines. Remember that the new machines are very sensitive to excessive suds and will even stop to allow the suds to go down before continuing on. More is not always better and with the washing machine of today, more may make it take a very long time to wash that load of clothing.
http://www.fixya.com/support/r4312694-washing_machine_maintenance
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
http://www.fixya.com/support/r3867591-washer_troubleshooting_water_not
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
http://www.fixya.com/support/r4356970-clean_washer
on Mar 17, 2010 | Washing Machines
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    GE WSXH208FWW washer leaving spots on clothes
    If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
    Aug 24, 2010 | GE WSXH208A Front Load Washer
    Detergent dispenser does not empty after washing
    it could be either a leaking water inlet valve or the pump is not emptying all the water from the machine and when it goes in to spin centrafugal force forces water back up the filler pipe
    Jan 17, 2010 | Kenmore 44102 Front Load Washer
    My bosch does not always completely wring the clothes out at the end of the cycle causing me to have to put the clothes through another wash. Has anyone had this problem?
    ...at the end of the wash, I then set the dial to DRAIN, then press start.  I wait for a special drain cycle to run.  Then, I set the dial to SPIN, and wait for a special spin cycle to run.  The clothes are much dryer and spun out after this process.  I'm not happy with the washer, it came with my new condo.  BUT, I'm trying to learn how to use it.....
    Aug 23, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Lg tromm front loading washing machine has
    Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
    BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
    Update me about your progress
    Jul 20, 2009 | Washing Machines
    Can you use Oxyclean along with detergent in front loaders?
    I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
    Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    64 people viewed this question
    Top Washing Machines Experts
