Question about Linksys WRT54G Wireless-G Broadband Router (LS-WRT54G)
Connectivity I have the following, and would like to know if could use only one of these devices to connect phone, and laptop, instead of the 2 I am currently using. Equiptment includes the following Linkesys broadband router with 2 phone ports-model RT31P2 Linkesys broadband wireless router -G, WRT54G. Currently I am using both of these, would like to condense to only one if possilble. Thanks Joe
  • sunnydogkenn Jan 07, 2009
    THANKS , ANSWERED COMPLETLY I HAVE TRIED AND WORKS GREAT, AGAIN THANKS
    President:
  • 623 Answers
Hi Joe,
That just depends on how you want to connect with your laptop.
If you need wireless access, then you have to use the WRT54G, because the RT31P2 has no wireless capabilities.
If you are connected via ethernet cable, then you can simply take the WRT54G out.
If you like to read up on different scenarios, here is my favorite page.
Enjoy!
Posted on Jan 07, 2009
How do i root LG tablet with computer?
Root LG Device with OneClick Root
  1. Step 1: Connect LG phone to PC and enable USB Debugging on LG phone by following steps. Drag and drop down the notification window. ...
  2. Step 2: Install LG Drivers on your computer. ...
  3. Step 3: Download LG One Click Root. ...
  4. Step 4: When connection is successful, click the "Start" key.
Oct 03, 2016 | LG Cell Phones
Nokia 5230 - problems using Bluetooth for connection with laptop
Dear friend i think your problem is that you are unable to connect your mobilephone with your pc via bluetooth. this problem can be arise due to 2 reasons 1.There are someproblem occured due to software. 2.And most probably the second problem can be related with your connection stack ,if your connection stack have been full then your cellphone deny to access on any other device. so for the reolving this problem follow the steps-
1->go to your cellphone bluetooth option. 2->select my devices, 3->select option. 4->select remove all from option. 5->again try to connect your phone with your system and now you can do it easily , NOTE-Please make pairing before transfering .
Aug 12, 2011 | Nokia 5230 Cell Phone
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Jan 27, 2011 | Nokia 2690 Cell Phone
Cannot connect laptop via bluetooth,idont kow problem is withn driver or do i hav to instal new driver .pl let me know
Hi friends
It s a simply way, to solve the problem.you will follow the instruction.
Follow the bellow step.
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same
number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect
using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user
name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone
mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
Jan 23, 2011 | Computers & Internet
Cant connect my phone to laptop
Dont worry all you need to is follow the following steps :
1.turn on the bluetooth in your cellphone or if you are using a USB cable so insert the CD for the cellphone
2.install the software for the cellphone in your computer as for NOKIA its NOKIA PC SUITE
3.turn on the wireless in your computer or connect the USB cable
4.for bluetooth connection only(go to bluetooth devices)
select add a wireless device
5.select your device
6.go with the Addition process and close the window
FOR USB CABLE CONNECTION
connect your phone to the PC and start working
Thanks
Regards
Hamid
Jul 15, 2010 | Computers & Internet
How do you connect printer to laptop with bluetooth
Hi friend,
follow the given below instructions-
1-Make sure your printer is Bluetooth enabled. Some printers come this way (read the manual to verify) but others require adapters. Shop online or visit an electronics store to find an inexpensive Bluetooth printer adapter.
2-Set up your adapter. All you need do is connect one end to your laptop and the other end to your printer and it will install itself.
3-Turn on the printer. Make sure it is connected to a working electrical outlet and the printer power is on correctly.
4-Open Bluetooth devices on your laptop. After installing your Bluetooth adapter, go to the control panel and open "Bluetooth Devices."
5-Add printer automatically. This is less secure, but easier. From the options tab, make sure the options "Turn discover on" and "Allow Bluetooth devices to connect to this laptop" are checked. Your printer and laptop should then find each other automatically and begin working. If you'd rather not let other devices discover your laptop, follow steps 6 and 7 instead.
6-Add device manually. From the devices tab, select "Add Device" and run the installation wizard to find your printe
7-Use the "Add Printers" wizard. You can also add the printer by clicking "Start" and "Printers and Faxes" and then "Add a Printer." When the wizard pops up, select "Bluetooth printer" and Windows will search for your printer automatically.
please rate me........
Thanks,
Mar 24, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Unable to transfer files to lap top
First install the LG software on your laptop called pc suite.if you have done this then on your laptop go to control panel then system then device manager then check whether the port on which you connected your handset is working properly.If yes then go and check the settings of the pc suite you installed.Did you enable file sharing on the suite?
Jan 13, 2010 | LG KU990 Viewty
Cannot connect to internet wireless
Please get to the router configuration console (Router GUI on 192.168.1.1) and click wireless => Try changing the channel number and if reboot the router and test for all 11 channels, incase if there is no diffrence please follow the steps below:
Wireless => Advanced wireless Settings => Change the following:
1) Beacon interval = 50 instead of 100
2) Fragmentation Threshold = 2306 instead of 2346
3) RTS Threshold = 2307 instead of 2347
Nov 18, 2009 | Linksys Wireless-G WRT54G Router
I want to connect my mobile phone to my accer through bluetooth
install the bluetooth software on your laptop bro and configured it.
Sep 15, 2009 | Acer Aspire 5315 Notebook
How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
Aug 05, 2008 | Motorola Mobility Bluetooth Hands-Free...
Linksys WRT54G Wireless-G Broadband Router (LS-WRT54G) Logo
111 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
