Question about Canon NP 7130 Black and White Copier
How do we empty the waste basket?
The waste basket light came on.. we is the basket located within the copier and can it be emptied or does it have to be replaced?
    New Friend:
  • 34 Answers
The "waste basket" is to indicate that the waste toner area in the drum cartridge is full. If the copy quality is still ok you may be able to empty the waste by removing the drum cartridge from the machine and removing the opaque piece from the left side and dumping it out. BE CAREFUL this can be very very messy. toner is a very fine powder and will get all over the place if caution is not used.
Posted on Jan 08, 2009
How do you empty the container?
You will first need to unplug your shredder. On either side on the shredder head, there are grooves. These are finger grooves. Place your fingers inside the finger grooves and lift up. This will remove the shredder head from the waste basket. Simply empty the waste basket, replace the shredder head and plug back in.
Jul 10, 2012 | Compucessory CCS 60062 Shredder
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Canon 2220i imagerunner how do you empty the waste toner container
Hello autumn,
Lets start with a reference,which will be standing in front of the copier. Ok,using this reference the waste toner bottle is located on the left side of the copier at the the lowest point of the left side almost at the back of the copier. If you have a stapler/finsher you will need to un-dock it from the copier and slide it away as far as possible, It need not be removed. Now you will have located a cover with one screw. Remove the screw and remove the cover.You now see the bottle.It has a handle so slide it out being careful not to spill it. You can of course pour the waste toner into a strong plastic bag,taking whatever cautions you see fit as you have one hell of a potential mess if not handled carefully.Once the bottle is empty, please notice the neck of the bottle. The way the copier "knows" the bottle is full is by sending a beem of infrared light thru the neck of the bottle. When the waste toner fills the bottle to the neck and blocks the beam of light the copier knows the bottle is full. My point is make sure you clean the neck of the waste toner bottle (if you look closely you will see the "windows" the light travels thru) by using a Q Tip or tissue. If the "windows" are clouded the copier will think the bottle is still full even though the bottle is empty. Does that make sense? In other words you could put a brand new waste toner bottle in the copier with black tape around the neck of the bottle and the copier would say the bottle is full.So now that its empty, and the neck is clean, replace the bottle and the cover.Turn off the "main power switch" located on the right side towards the rear of the copier.Wait a sec, turn it back on and you should be in good shape.Take care and let "FIXYA " know if I helped please. SPINAL
Feb 15, 2011 | Canon imageRUNNER 2220i Grayscale Copier
What is the problem if RICOH AFICIO 352 display "waste basket full" though the wastes basket is empty?
I believe there is a connector in the front of the bottle. Turn the copier Off and plug it back in. If there is not, then there is a waste toner holder in the transfer belt unit. It dose not fill up offten, it took me a while to find it the first time.... Good Luck
Sep 11, 2010 | Ricoh Aficio 450 Copier
How do you empty the waste toner bottle? And where is it located?
on the cf2001 the waste bottle is located on the left side door but to empty is going to be difficult and messy, there is an auger that you after turn while you angle the opening of the bottle toward a garbage container to empty it, the bottle is really a rectangular container with a notch in the top middle portion that needs to be clear of toner because a optical sensor sees through it, or else it will still give you the message empty waste bottle, it is easier to have an extra empty waste bottle to replace it.... hope this helps
Dec 29, 2009 | Minolta CF2001 Copier
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Emptying waste tone cartridge
You need to replace the waste toner bottle (packaged with a new toner cartridge) you can't just empty it. There is a photo sensor that "reads" through a window of the waste bottle. The sensor could be dirty. Clean the slits with a q-tip.
Oct 01, 2008 | Kyocera Ai3010 Copier
Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
Canon NP 7130 Black and White Copier Logo
117 people viewed this question
old marine
old marine
