Question about Riso RZ220 Duplicator
Rizo RZ220UI drum will not go completely back into machine
This has happened before but we had our resident expert here. He is gone now and we do not want to damage the machine and need advice. The drum goes nearly in and the front door will not close
  • ritabochita Jan 07, 2009
    the drum went in but the light is still on and I can't get it to function. I unplugged it hoping that it needs reset. any advice
  • 148 Answers
The drum fits into a drive cog on the back side
pull the drum out look at the way it is inset and push back in with pressure and rotate until it goes in a little farther then you should be able to close the door
ther should be some type of latch or knob to turn when you get the drum in positon
Good luck
Posted on Jan 07, 2009
  • Steve Archer Jan 07, 2009
    remove the paper feed area and look for any paper in the feed and exit area
    also make sure all safety switches( door switches and levers) are properly closed
    also look for a reset button usually a black button inside door where latch is
    the light indicates a switch is open just tap on all doors with the palm of your hand or open and close firmly
Spin - loud noise - switched off - drum wont turn
I'm just hazarding a guess here, but it sounds like the bearings have gone (if you try to turn the drum by hand and it sounds noisy and grinding/crunchy then I think it would be the bearings). I'm certainly no expert though.
Feb 02, 2014 | Zanussi Washing Machines
Ic regulator of model: 14PT332/00
This is device that control output voltage for digital circuits, audio, etc is very importante, otherwise this circuit of tv or any device electronic the function had not stabilize, creating spike, rizo, or glitching in the circuit producing NOISE.
God bless you
Jul 18, 2012 | Televison & Video
Drum bearing has gone on an AEG 72640 washing machine - is it a drum out repair or can it be done with drum in situ ? I can see that the bearings are available no problem. Would any other seals be needed...
These machines are not a quick one to repair, they have 2 bearings (inner and outer) plus a lip seal. you have to completely dismantle the machine to replace the bearings.
Oct 25, 2010 | Washing Machines
We have a Rizo 220 ui with an error message
The rear cover may be off. Or you may have a bad cover switch.There are two switches at the top of the back coverone on the left and one on the right. Hope this helps.
Jul 14, 2010 | Riso RZ220 Duplicator
Small flecks of dirt on clothes
If its noisy too then sounds like drum bearings gone / leaking oil/grease...
Apr 12, 2010 | Washing Machines
Error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Nov 30, 2009 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
I need to replace the bearing in an AEG Lavamat 1450. I've taken the back off the machine, but there isn't a traditional "spider", just a round wheel type thing attached with an Allen bolt. Can I have some...
Hi there.....unless your exerienced in this advise you to seek expert help...the drive wheel securing bolt is of the torx type and requires a secial torx key to remove will find that the outter drum has a series of torx headed screws around it which have to be removed and then the drum split...only after this has been completed and the inner drum removed will you have access to.the bearings.......
regards Sir Galahad
Aug 20, 2009 | Washing Machines
Clothes coming out with grease marks on them ,washer jumping and not always completing sequence
seems like main bearing under drum is shot and transmission oil comming up. is this an old machine?
Jul 30, 2009 | Washing Machines
Hotpoint washing machine
this is your that are gone these are at the back of your drum on the inside if these are gone then these will need replacing by a professional its a complete strip down aswell as stripping inner and outer drum apart from each other but this is a costly job £125+sometimes more economical to replace the washer only £100 more to get a new washer and have 12months warranty this way also if you have it done you will lose your washer for about 3days. to make sure they have gone take the lid off and look down to the middle of the drum at the back there should be some rusty water marks going down the drum also you can place your fingers to the inside of the washer while having your palm on the front of the washer if it lifts its the bearings from what you say though it will be the bearings m8
Oct 16, 2007 | Hotpoint Aquarius WD63 Front Load...
294 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
