Question about Nikon D80 Digital Camera with 18-135mm Lens
Your answer to my poor focus problem
Not sure I understand your answer... you say I can toggle around the focal point in the viewfinder using the menu switch... in what setting or menu item is this possible?
Also, what do you mean by this: evn try amnually focusing on your subjects.
  • usandy Jan 07, 2009
    Well, I've had an interest in photography for over 25 years, but this autofocus threw me. The viewfinder looks so crisp, but the image is so fuzzy.... I use a tripod, stopped down past 8, a remote for the shutter but still sometimes the shot is poor. I now do not use a UV filter... hate to do that because of potential damage to my lens surface, but it has helped a bit...
    Novelist:
  • 121 Answers
Usandy,
sorry about my mad typing skills, you can set the focus to wrap around as you toggle with the menu switch while looking thru the viewfinder to set your focal point in the picture. (it is in the settings menu)
The other part was you could "even try manually focusing on your subjects" in manual mode. Are you new to photography / digital cameras?
randy320sgi
Posted on Jan 07, 2009
Camera mounted on tripod. 61 focus points, but my focal point lies outside of all of those 61. how do i focus, since i can't recompose on tripod? thank you!!
Put the camera in manual focus. Switch to live view and digital zoom in to the subject you want to have in focus. I think that will work. With 61 focus point, it will have live view.
I perhaps could have given a more detailed answer if I had known what camera you are using, like the band and model and eventually what lens. (also brand, model, focus length and diaphragm.
Mar 09, 2015 | Cameras
How to use Nikon Pk-3 extension tube?
It should work with just about any lens, though it works best with moderate focal lengths (say about 24mm to 200mm). Its primary purpose is to let the lens focus much closer than normal.
When you say "no results," do you mean it's not letting you focus closer? Mount the tube on the camera, mount a lens on the tube, then focus the lens to its minimum focus distance. Looking through the viewfinder, move closer to an object until it comes into focus. Does it come into focus? How close? What lens(es) are you trying?
Jan 03, 2013 | Nikon Pk-3 Extension Tube Make Lens A...
My webcam is blurry. But the camera is not dirty. I don't know what the problem is. Its fairly new, I got it about a month ago but haven't used it much. It's the Logitech, HD 720p.
Hi ihtstasiaax
Try gripping the lens frame and twist to focus the lens to the desired focal length/resolution.
Also with some webcams it is better to install the software first, restart the computer then connect the camera.
Disconnect Webcam > Remove all components of the camera software in Add or Remove Programs > Apply > OK > Restart computer > reinstall camera software > Restart computer > connect camera > focus lens to desired focal length/resolution.
If this does not work it may be faulty and should be returned under warranty.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 07, 2011 | Logitech Webcam
I have a Barska telescope. Model: 60800. Diam: 60mm Focal length: 800 mm. I think I put it together correctly, but I can not see anything through it... just black. Yes, I have taken the cap off the...
The power of the scope will be the focal length of the main objective (yours is 800mm) divided by the focal length of the eyepiece, so a 9mm eyepiece will give a higher magnification (and be dimmer and harder to focus and find objects) than a 20mm eyepiece. It is usual to have two or three different focal length eyepieces for viewing different objects.
Starting out, you want to use the lowest power, so the highest number, eyepiece. Do NOT use the Barlow lens if one came with the scope. Try it out during the day (but never point a telescope anywhere near the Sun). This will make it easier to find the focus point. There is a very wide range of movement in the focus mechanism, because different eyepieces focus at different points, but the actual focus range for any eyepiece will be a small part of the overall range afforded by the focusing mount.
It is unlikely that the finder scope will be much use in pointing the telescope until you adjust it to precisely line up with the main scope. Most manuals recommend that you do this in daylight, by pointing the scope at an object on the horizon and adjusting the finder to match. Once you have a tree or mountain peak in the center of the main scopes image, you can then adjust the screws around the finder scope to get the crosshairs centered on the same object. It is very difficult to do this job in the dark, especially as objects in the sky are constantly on the move.
Remember that astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear. It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one.
Dec 31, 2010 | Optics
Sigma 70-300mm lens defaults to manual focus
It will default to manual through the viewing screen. It will only work on automatic, using the viewfinder. Make sure you also set the focal length (lens to shutter distance). You might also have a mf / af switch on the lens. This also only works through the viewfinder.
Jan 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Silly question re manual focussing
What you are looking at in the middle is called a split prism whilst it is good to determine focus you have found the one short fall.
You will notice that it gets worse with the longer focal length lenses, when you have the half black image, just try moving your eye around the viewinder up, down, left right, you will find that the half that is black may change, the black is caused by poor alignment of the eye in relation to the optical axis center of the viewfinder system.
Not a fault or problem as such just something to be aware of and try to work around it.
Aug 20, 2008 | Minolta X-700 35mm SLR Camera
Re: poor focus problem
usandy,
You can set the focal point by toggling the menu switch (you can see it moving around into different locations as it "wraps" around the viewfinder, now depending on your f-stop the area that is not in focus will be soft, you can also experiment with the autofocus lock on you subject and evn try amnually focusing on your subjects.
randy320sgi
Jul 21, 2008 | Nikon D80 Digital Camera with 18-200mm...
My camera cannot focus
Are both the lens and camera set to autofocus?
Jan 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My Canon digital rebel will not autofocus correctly. My camera has 7 points autofocus, but it will only autofocus on the far right point. All other points are not used. I have had the camera for 14 months...
I had this problem awhile ago - you must have accidently adjusted the focal area - it is sooooo easy to do without realising it. Here is what I was told:
Most likely, you have changed the AF point, which only takes effect in the creative modes (Manual, Av, Tv, P, etc)
There should be a button on your camera that has a grid like pattern above it, like
or so. press that, look through the viewfinder, and move the shutter or rear wheel, you should see the different AF points like up in red, and as you turn different ones will light up, and eventually all of them. also, you can look on the screen on top (or back, if its a rebel) and it will show you which ones are selected while in that mode, instead of looking through the viewfinder.
Nov 07, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
