Question about Maytag Neptune MDE6700A Electric Dryer
Problem when drying gets to 1 minute mark
When my dryer gets down to the 1 minute mark, the the two digits start displaying one large rotating circle and the drying continues. This goes on for a couple of times and then finally stops. The manual troubleshooting guide makes no reference to the display making one large rotating circle. Why does my dryer want to do this at the 1 minute mark?
  • 20 Answers
This is happening when you selected the wrinkle prevent option or you set it to wrinkle release cycle.what it does is it is tumbling with no heat to release the wrinkle in the clothing. This is normal.It could also be normal part of drying in "regular" cycle
Posted on Jul 21, 2007
What does f01 mean
From the Maytag support website:
Product Symptom:
F01 Error Code
Control displayingF01:
There may be a problem with the Main Control Board, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Start a time dry cycle.
Monitor the dryer for one (1) minute to ensure the error code does not display again.
Jan 24, 2016 | Maytag Dryers
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
Samsung dryer gets to one minute mark and displays a circle and the clothes come out cold
there is self diagnosing test you can run. to verify what your machine is trying to say with the circles
Jan 07, 2013 | Samsung Dryers
Whirlpool wed5840sw0 dryer NOT STARTING
not make for large blanket change the white fuse air not going out
Nov 13, 2017 | Whirlpool GEW9250 Electric Dryer
Periodically, the display will change to the wrinkle release mode from sensor dry mode (all by itself), and the timer will show 18 minutes remaining. If I switch it back to sensor dry mode, the display...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing, if that is fine the problem is either the door switch or the control board. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Model MDE9700AYW: I set the timer for a certain amount of time (say 30 minutes). I come back 45 minutes later and the dryer is still running. There is also a "racetrack" in the display. No error...
Instructions
1. Break your load down into smaller groups. Large, saturated blankets, duvets, blankets and other upholstery can be too heavy for the MDE9700AYW to safely dry. Dry large large items one at a time with some smaller items such socks and underwear to better balance the load. One washer load should equal one dryer load.
2. Confirm that the cycle selector has been pushed down and the dryer door is latched shut. When the dryer door is opened, the cycle is temporarily paused to protect you from injury. Press the cycle selector down to resume the drying cycle once the door has clicked closed.
3. Examine the circuit breakers or fuses in the dryer's electrical circuit. The Maytag MDE9700AYW needs two active fuses or breakers, depending on your home, to operate its electronics and spin the drum. The dryer may not spin if either one of the fuses or breakers is inactive.
Feb 24, 2011 | Maytag Dryers
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
The drum doesn't rotate and a strange buzzing noise occurs
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE;
Aug 22, 2008 | Zanussi Dryers
Initial gas burn does not reignite
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Hope this may help;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Spins but no heat
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Apr 11, 2008 | Whirlpool LGR7646E Dryer
Maytag Neptune MDE6700A Electric Dryer Logo
240 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
