Question about Sony STR-DE685 Receiver
Protect mode turns the reciever off at fairly modest volumes
Sony STRDG720 AV Reciever
I Had the same problem.
It occurs when you have a speaker wire touching something that it shouldnt and and you are grounding out the system. The system is going in to protect mode to keep itself from being damaged
In my case I found that I had a couple of frayed wires from one of my back speaker terminals touching the wire on the other terminal. This was all it took. I re-inserted the speaker wires on that one particular speaker and made sure they were not touching and problem solved.
JPT
Posted on Mar 30, 2009
Sony reciever shows protect on display
May be bad connections on the preamp ic's. Otherwise there is a short in the amp that needs to be repaired.
Jan 02, 2013 | Sony Str-d350z, Av Am/fm Reciever, Home...
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
My stereo keeps saying ''protect''. how can i fix it? ive tried to unplug it for 4 hours and it still dont work
Check the speaker wire connections and make sure that none of them are crossed. Shorted wires will cause the reciever to turn on the protect mode to keep the amplifier from shorting out. Try disconnecting the speaker wires from the reciever. if you turn it on and it still says "protect" then the short is possibly in the reciever itself.
Nov 08, 2009 | Cars & Trucks
I have just purchased a home cinema system: SONY 46" LCD, KEF3005 SPKS, SONY STRDA2400ES RCVR, SONY S55O BLURAY. ALSO A VIRGIN HD+ BOX. CAN YOU ADVISE BEST WAY TO CONNECT THIS ALL TOGETHER FOR BEST...
connect all source devices to the Sony LCD tv inputs. and connect the audio output from the tv to the aux input or any one input of the audio reciever. This way you can just leave the av reciever on and control all the input switching with te tv remote. Avoid connecting all the av sources to the reciever and the tv as a monitor from the video out of the av reciever. Just use the av reciever to reproduce the desired audio and do all the input switching with the tv remote. This will simplify the operation an lessen the chance of someone changing the audio settings of the av reciever.
Aug 29, 2009 | Audio Players & Recorders
Sony STR DE 197 Reciever with No Sound
I have the same unit. My best recommendation would be to remove all speaker wiring, and try new wiring with another pr of speakers,since the "outdoor " speakers were rained on. the protect mode that the unit went into sounds like it did because the speaker outputs were shorted due to the rain, so ensure that the speaker output terminals are not shorted and dry...also see if output is still availalable at the headphone jack...if it is, the pre-amp section is still good , in which case the protect mode and no volume output out of the speaker jacks may mean that youve blown the ouput trasnsistor finals.
I hope this helps.
bobbymaximus
Jul 28, 2009 | Sony STR-DE197 Receiver
Protect displaying
Protect on any reciever usually means that it has reached its maximum capacity of volume (known as clipping) and at the reciever is now automatically reducing the volume to avoid damage. This some times is triggered if the reciever was used hard and is now damaged so you would need to bring it to a repair shop. Sometimes its caused by a bad wire to the speakers, a short to say. Check all your wiring, make sure its not overheating and getting plenty of air. Some where its recieving a signal telling it to go into protect mode.
Joe
May 28, 2009 | Audio Players & Recorders
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Protect mode
You may have loosened a solder joint on one of the components inside with your air blast. A repair tech would monitor the outputs DC offset voltage and he will probably see one that is not zero volts and while wiggling various things he should see a sudden change in the DC offset voltage on the bad channel when he touches the bad connection. Then it's just a matter of resoldering the connection. Good luck on this one.
May 02, 2007 | Sony STR-DE425 Receiver
Sony STR-DE685 Receiver Logo
353 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
