Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights Logo
Posted on Jan 07, 2009
Trying 2 wire a ceiling light
I have got 2 black wires and 1 wellow and green wire coming out off the ceiling dont know why ive got 2 black wires
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jan 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
Helped
5509
Points
21
ONE IS NOT REALLY BLACK, YOU NEED TO TEST THE VOLTAGE WITH A VOLTAGE TESTER. tHE TESTER HAS TWO SHICKS PUT ONE ON THE GROUND(GREEN AND YELLOW) AND THE OTHER TO ONE OF THE BLACKS THE ACTUAL HOT WILL SET OFF TESTER. THAT IS YOUR BLACK THE OTHER IS THE WHITE
3answers
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
Nov 11, 2017 • Dryers
1helpful
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
1helpful
How wiring a new ceiling fan in a 1995 mobile home that is controled by a wall switch and controls 2 fans
Should be Bk &Blue(wirenut togerher) - bk, white - Wh, Green - green
Aug 28, 2014 • Dryers
Wires coming out of ceiling to connect ceiling fans with lights
I don't know what the question is! I don't know that fan but if it's a ceiling fan & you only have one hot wire then you would wire it this way; White to white, green to green or ground, & black & blue from fan to black house wire.
Aug 16, 2014 • Dryers
Replacing fan. Wires from ceiling are grey pink white & bare copper. Wired to light switch. What wire connects to what? Ok so we just bought the place. The painters removed the old fans that had no...
Sounds like you have two hot wires. Just need to find out which wire goes to the wall switch. Try gray to black from fan,pink to black/white wire.white to white & green to green. If this doesn't work swich the pink & gray wires.
Feb 03, 2013 • Dryers
1helpful
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
1helpful
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Wire a ceiling light
is your house older, Some old wires its hard to tell which one is the grounded conductor(nuetral), Both Look black. If this is case You need to test it with a voltage tester- The green and yellow is a ground wire. Test the green with the voltage tester, Along with one of the blacks, if the Black and green set of the voltage tester that black is the hot. hook it up to the black on the lt. hook white to the other black. and green to either green screew or ground wire which ever is provided
Hampton Bay Model 73554 Ceiling Fan
Its not hooked up right.
Black is hot , Black to Black always.
green is ground , usually the green grounds to the mounting screws without any connections needed.
the rest are variable
you can have only 1 or 2 extra wires left.
one to fan , one to lights,
either way they go to white (neutral)
Do you have a dual wall switch with lights and fan or are you using the remote?
How many wires and what color are they that comes out of the ceiling box?
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Top Solar Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Bob Kirkwood
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
