Question about HP LaserJet 3600n Printer
Hp laserjet 3600dn driver - Cannot use on 2003 server
A customer wanted us to recreate the print queue of their network printer. When I went to install the drivers it died and would not complete. I have used every driver that HP has listed on their site. Do you have any ideas?
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Hp laserjet p1008 printer sharing print command stuck in queue
Which OS is this? If its on Windows 2003 or 2008 server then using the print management console as opposed to the start > printers option should resolve this issue. Print console can be found under admin tools in the start menu
Dec 07, 2010 | HP Color LaserJet 2600n Printer
Suddenly our company have customers who can no longer print to HP networked printers (NDPS queue based). Their neighbor can print to a printer, but they cannot print to the same printer - cannot print test...
Hi, Apart from the print drivers setup, there is the print server which usually hangs due to overflow for requests.The priority of the print plays a major role here as the highest priority print occupies the first place, and thereby prolongs the successive prints and due to the volume of the network it hangs. Solution: Restart the print server and delete the prints in the queue Restart the printer as well and check the spool process
Hope this helps
Nov 04, 2009 | Microsoft Windows 2000 Professional for PC
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Oct 26, 2008 | HP LaserJet 1018 Printer
Lj2600n no output
i need HP colour laserjet 2600n software supporting to windows vista
May 07, 2008 | HP Color LaserJet 2600n Printer
Laserjet 1022n and Universal Print Driver
i solved this problem in my case with an compatilble standard driver from windows. An PCL Laserjet 5 / Laserjet 6 Driver.
And no problems occour.
On the clients and the server all iss fine.
Apr 07, 2008 | HP LaserJet 1022n Printer
3600DN
Reinstall printer driver this normally works
Thanks J
Jan 21, 2008 | HP LaserJet 3600dn Printer
HP LaserJet 3600n Printer Logo
218 people viewed this question
Ben Johnson
