Question about Dell Inspiron E1505 Notebook
Dell Insp E 1505 goes to User accts screen and nothing further
I log onto my laptop and I see the user accounts selection screen, my mouse moves but i cannot select anything. I cant select an account or even turn off computer. I can start in safe mode and select whatever i want but it will not connect to the internet that way so I cant see if there is a vitus or something. I created a new account from safe mode to see if that would work but it didnt. I do not get ANY error messages at all. Have you ever seent his or heard of this before? Any idea's?
  • 2 more comments
  • shannyatwork Jan 07, 2009
    Will I loose any data by doing the system restore? I have about $1000 of itunes on here..
    Do I complete the system restore by right clicking on My Computer (in safe mode) and going into Manage > System restore? Or is there another route I should take?
  • shannyatwork Jan 08, 2009
    I tried safe mode with networking but it will not connect to the internet. Will system restore erase my files?
  • shannyatwork Jan 19, 2009
    I cant even get into safe mode now.. Is there another way to get to system restore? If i run a scan disk I get error C000021a Unkown Hard Error.. Am I dead in the water at this point? should I just re-install windows?
    President:
  • 1,990 Answers
Welcome to Fixya! No, System Restore will not Erase your Files as Long as you Saved Regularly and were not Working on Any Unsaved Documents at the Time. Is simply Reverts your Hard Drive back to the Point Before the Error Occured.
Posted on Jan 08, 2009
    President:
  • 2,110 Answers
You have to do a system restore..this process don't deletw ur files...
  • 15,935 Answers
System restore does not change, delete, or modify files or installed programs. Only registry changes are rolled back.
There is also a disclaimer when you roll back... that you can UNdo the restore if it does not have the desired effect you are looking for.
Start in safe mode, and make a backup of your music before if you are wary.
  • Dell Master
  • 6,487 Answers
You wont loose any data in doing system restore it will just bring the computer back to the date when it was working fine, updates and recently installed program will be gone when you do a system restore but the data that are save should still be there...You can do it this way Click start>programs>accessories>system tools>system restore.....
Posted on Jan 07, 2009
  • 679 Answers
Yes when you restore your system all the data will be lose.
  • rockfixya
    rockfixya Jan 07, 2009
    yes all the dta will be lose but
    if the data copyed before to restore point date than the data is safe.
    Thanks for using FixYa
  • rockfixya
    again warning --
    yes all the dta will be lose but,, if the data copyed before to restore point date than the data is safe.
    note: it depands upon the date of restore and the date of data copyed.
    Brigadier General:
  • 5,158 Answers
Boot normally... use your tab key to hilight the account you want... then hit enter
Did you just install a usb mouse ?
    Sergeant:
    Champion:
  • 304 Answers
No. you may not lost your files. it will only restore it into the previous state that it work normal.
  • 42 Answers
Try putting this program on a thumb drive: http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Boot in safe mode and run the installer, you won't be able to update the database but it will still catch anything completely hijacking your system. The system restore is a great idea too if it's successful. My experience has been with more newer viruses have installed themselves with registry changes etc. and are actually attached to system restore so my opinion would be to try to run one first if it doesn't work DISABLE system restore which will delete the previous data. Then run that program and see if that gives you some breathing room to really get in and run a full antivirus/antispyware scan.
  • word2thewhys
    word2thewhys Jan 07, 2009
    I have seen this before, with different viruses. Your system restore shouldn't delete your iTunes which is why I think it probably won't fix your problem either since it doesn't remove any saved files.
    Genius:
  • 1,550 Answers
In safe mode with networking you can connect to internet .
  • Dell Master
  • 13,433 Answers
To get internet in the safe mode use the safe mode with networking option when you tap f8 in the start up.
if you are unable to recover from the problem,
try a system restore and if that fails reload windows to the laptop.
  • Dell Master
  • 4,806 Answers
Hi there
Boot into safe mode and perform a system restore, take the machine back to around a week before the problems started, when you gain access to your account scan the pc straight away for viruses
Good luck and kind regards
  • Lee Hodgson
    Lee Hodgson Jan 07, 2009
    all your data should be safe if you perform a system restore, if you are not too sure move all your docs, movies and tunes into your documents folder, system restore will not effect that folder.
    System restore is located "programs" "accessories" and "system tools"
    Good luck
  • Lee Hodgson
    Lee Hodgson Jan 19, 2009
    Hi there.
    This isn't just a problem with the operating system, there seems to be a problem with the hard drive too, probably bad sectors! this is the reason why system restore is not working for you. Reinstalling the OS will not resolve the issue but you will run into major problems during install, then you will be at your wits end.
    If you need your previous data from the hard drive, take it out and connect it to an up-to-date desktop PC (you may have to get the correct leads) the desktop will see the drive as a slave device and you will be able to get your data from it and also check the drive for bad sectors and recover them using that PC.
    Put the drive back into your machine and try to restore again, or reinstall the OS, if you still get error messages, for example can't copy "file.dll" i'm in no doubt its the hard drive which has degraded
    Good luck
I have an password set up as an administrator and anothr user account. i just tried to log on under the administrator acct which is mine and it says my password does not work. i have not changed it and...
If your user account has administrator rights then you can fix the administrator password.
Go to Control Panel - User Accounts and click on the administrator account to change or remove the password.
If you do not have administrator rights then -
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jul 15, 2011 | Gateway Computers & Internet
Tip
How to Reset Dell Password On User Account Without Reset Disk?
<span>User accounts are the primary means of access for real people to the system, and these accounts insulate the user and the environment, preventing the users from damaging the system or other users, and allowing users to customize their environment without affecting others. Meanwhile, the user accounts in Windows help PC administrators or owners add a basic level of security for their data or files. However, the bad news is what should we do if<span> </span><a href="http://www.passwordunlocker.com/knowledge/forgot-windows-7-password.html">forgot password for Dell PC</a><br />?Of course, you can password reset disk and you have no administrative privilege, what should you do to regain access into the Dell laptop? Is there any portable way to deal with?<br />Here introduces a step-by-step guide on how to access the user accounts and we would like to take Windows 7 as an example.<br /><b>Instructions to Change a User Account Password on Dell PC</b><br /> <ul> <li>1. Turn off and restart your Dell PC. Press and hold the "F8" key during the start-up process to enter the Windows "Advanced Boot Options" menu.</li>Note: "F12" or other keys can be available if your screen indicates<br /> <li>2. Press the down-and-up arrow on your keyboard to scroll down and highlight "Safe Mode." Press "Enter." This will take several minutes.</li> <li>3. Click on the "Administrator" account listed in the Windows log-on screen and enter the Administrator's password to log into the account if you have.</li>Note: This account sometimes gets created by default when you or the PC's manufacturer performs a fresh/new installation of the Windows operating system on a PC.<br /> <li>4. Click "Start" button and type "User Accounts" in the search box at the bottom of the "Start" menu. Press "Enter."</li> <li>5. Select "Manage another account." Click on your user account name or another user's account name.</li> <li><br /></li> <li>6. When the User Accounts appears, click it.</li> <li>7. Click "Change the password." Type a new password for the under accounts. Then click the "Change password" button.</li> <li>8. After that, restart the Dell computer. Log into the user account with the new password and you can successfully regain access your Dell PC.</li></ul>Do you feel relaxed with this detailed guide to change the user accounts password? After that, try to DIY and create a Windows password reset disk for your Dell laptop.<br />By the way, we have collected some other portable solution to<b><span> </span><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Dell password</a></b>, a helpful trick for taking<span> </span><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a><span> </span>which is much time and energy saving to do so by creating a Windows password reset disk.<br /></span>
on Mar 25, 2011 | Computers & Internet
I have a dell inspiron with windows 7, and everytime I try to log on it tells me windows has failed to open. It gives me the system restore option but when I use it it just sends me to the screen where I...
press ctrl + alt + del and see if a menu screen appears if it does select task manager then click file and click new task and type explorer and press enter. See if that allows you to start windows. If it doesnt restart the computer and keep pressing f8 till you get a menu up askingif you want to start normally etc choose safe mode, select it with the up and down arrow keys and press enter. when windows loads up choose administrator and log in you will then have to setup a new user account. click start > control panel > user accounts. Create a new user account (dont use the same name as you used before if your user account name was kyle call the new one kyle1. then restart the laptop again and try to log into the new user account. Report back if you can and i will explain how to recover your old account
Apr 16, 2011 | Dell Inspiron 2200 Notebook
Cannot access my account
I assume you cannot log into your user account in Windows.
This is how to create a new user account to log in and to move your user files from the old account to the new one.
Start the computer and keep pressing F8 until startup menu appears. Use arrow keys to select "safe mode".
When windows appears, log on as Administrator.
Use Control Panel, Users and create a new user. Select Computer administrator type. Restart the computer and log on to the new user account. Then you will have to move all your data files:
Open Windows Explorer, navigate to C:\Documents and settings\[your old user account]
Select folders Desktop, Favorites and My Documents (this may appear as [User]'s documents) and copy or cut them. Go to c:\Documents and settings\[your new user account] and paste them here.
You will lose only the desktop picture and some windows settings.
After that you may delete the old user account from Control panel/Users
Aug 08, 2010 | Computers & Internet
Desktop freezes..no icons..nothing!!!
hi... login to safe mode by tapping F8 before u seee the Windows Xp Splash screen... select the option SAFE MODE and wait for a while u ll get the desktop.. then go to USER ACCOUNTS in Control Panel.. and create a new user account... and delete the previous account.. While deleting Make sure to select the option DELETE ONLY ACCOUNT dont select Delete files k... The files from the previous acconut will be saved to the desktop of the new account..
Sep 20, 2009 | HP Pavilion dv1000 Notebook
User Id
Enable or Disable Fast User Switching Note: To enable Fast User Switching, you must also enable the Use the Welcome screen option. This feature cannot be used if your computer is a member of a domain. To enable Fast User Switching:
  1. Log on to the computer as an administrator.
  2. Click Start, click Control Panel, and then click User Accounts.
  3. Click Change the way users log on or off.
  4. If it is not already selected, click to select the Use the Welcome screen check box.
    NOTE: The Use Fast User Switching check box is unavailable until you click to select the Use the Welcome screen check box.
  5. Click to select the Use Fast User Switching check box, and then click Apply Options. Quit the User Accounts tool.
Please don't forget to rate this solution.
Jun 15, 2009 | Dell Latitude C610 Notebook
My password is not working and I can't get into my laptop
is it Windows XP Home or Pro?
If so, shutdown the laptop, turn power on, and after the Sony splash goes away tap the F8 button several times until you see menu come up. Select the first option "Safe Mode". Allow the computer to boot to safe mode. It may have you select a user to log into, you need to select Admin. Provided there is no password to the Admin account, login and goto control panel. Under control panel select the Users icon, once that windows has come up, select the user acct that has the bad password, and select Remove Password. That will remove the password to that account.
Hope this helps you. Please rate my solution.
May 19, 2009 | Sony VAIO Notebook
Vostro 1500 DELL won't start
If you have almost given up all hope, you might want to try doing what I tried: Please search this topic here at fixya:
Dell Vostro 1000 won't turn on/no power at allI hope it helps, Rod
Feb 23, 2009 | Dell Vostro 1500 Notebook
Delete former user from laptop
Hi lily - If your running Vista here's how :
1. Log onto the computer using an account with administrator privileges.
2. Click the Start Button.
3. Click the picture associated with your account at the top of the menu.
4. Select Manage another account.
5. When the UAC box pops up, click Continue.
6. Select the user account that is to be deleted.
7. Click Delete the Account.
8. You will be asked if you wish to keep the files from the deleted account. To save the account's desktop and personal files to your desktop, click Keep Files. This will place the files into a directory with the account's name onto your desktop. Otherwise click the Delete Files button.
9. Click Delete Account.
If your Running Xp here's how:
Log on as you( by now I think everyone knows they should give themselves adminstrator priviledges)
Start>comtrol panel>user accounts>pick an account to change>delete account.
If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 17, 2008 | Dell Dimension 4300 PC Desktop
Porteage m400 laptop
maybe you can try another fingerprint? or maybe the lens needs cleaning?
Feb 21, 2008 | Toshiba Portege M400-S4032 Notebook
Dell Inspiron E1505 Notebook Logo
19 people viewed this question
Alun Cox
