Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My picyures come out with lighter color stripes down them. I just
Put in new cartridges what do I do?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
When printing with new ink cartridges the colors seem to line with different striped colors other than what is on the screen.
You may need to perform a align cartridges if you still face the same problem then you might need to do head clean by putting the cartridge heads in warm water for like 5 minuts and then put them back hopefully this shall solve your problem.
Oct 02, 2013 | HP B210a CN216A Photosmart Plus All-in-One...
Colored stripe down the edge
Sounds like the transfer belt could be bad, however if your lines are just 1 color than replace that color toner cartridge
Aug 05, 2012 | Brother HL3075CW - HL-3075CW Wireless...
Is there something I can clean on my HP Laserjet 2600n. I've done the recalibration and things that are built into the menu system. The colors appear faded, especially red. There's an echo-type of...
Using the REPORTS MENU print the "color supplies status". Make sure everything is good.
Select SYSTEM SETUP. Select PRINT QUALITY. Select CALIBRATE COLOR. Select CALIBRATE NOW.
Check the Transfer Belt(ETB) which is inside the front door. Make sure that it is free of your "racing stripes".
You can use HP TOOLBOX to troubleshoot.
You are using HP cartridges???
Dec 12, 2010 | HP Color LaserJet 2600n Printer
Keep getting right cartridge incorrect. what does this mean?
For the check cartridge error:
Gently clean the contacts in the carriage, and on the cartridges with a paper towel or coffee filter moistened with water.
For the poor print quality or missing print:
Perform the Blot Test
Remove cartridge from machine, fold a paper towel back over a couple of times so it is about 4 layers thick, shake cartridge up and down hard, shake it over a sink unless you want to clean ink off the floor.
Now blot the nozzles of the cartridge on the paper towel, for a black cartridge you should see two black stripes, for a color cartridge you should see three colored stripes, if you don't have all stripes the cartridge is clogged or bad.
Have you checked the expiration date on the cartridges you are using?
Are you installing new HP cartridges, or refills?
You may be able to recover a clogged cartridge by swishing the tip in a saucer with a very small amount of warm water, then gently wiping it on a wet paper towel, be gentle the nozzles are delicate.
And do not trust the ink gauge on the PC, cartridges can dry up from the machine just sitting, the cartridges are vented, venting is necessary to let air in so that a vacuum won't develop in the cartridge. get more information and help for HP Printer Ink Cartridge .
Sep 01, 2010 | HP PSC 2110 Color Printer
Color prints out photos in stripes
if you are getting stripes in photos then there is a problem with cartrige, take a cotton swab and dip it in water and clean the cartridge head and then try, and if still the same problem exist replace the color cartrige.
Feb 14, 2010 | Office Equipment & Supplies
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
66 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
