Question about Rosewill TU-155 BLACK 400W ATX Mid-Tower Case
I have no power
I have installed everything correctly (i think so at least). the mobo has a green light which means it is getting power but when I switch on the power switch on front of case It has a quick flash of power then nothing.
  • erchick_2 Jan 07, 2009
    I tried that and nothing. i feel like i hooked up the front power button to the power supply wrong. but don't know what else to do.
  • 716 Answers
Try Disconnecting The Hard Drives Then Powering On To See If That Works.
Posted on Jan 07, 2009
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
On the zt1135 pavilion the brand new battery won't charge. It is the correct battery replacement. OS: windows xp home edition. The orange light on laptop lights when battery is charging. Well, after...
well it can only be 3 things
bad battery
bad power pack
bad mobo.
the mobo as a charge chip, the power pack is just 19vdc .
if the chip is bad or there are shorted modules on the MOBO
the charging will fail. (battery good.)
is the power pack new, and 19vdc and at least 65watts>?
Jul 16, 2017 | HP Pavilion zt1135 Notebook
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
PC beep 5-2-2-1 code on startup, no posting
did you try to install one stick then see if it boots if it does move that one stick to all the different slots to see if you have a faulty slot and then see if you have a faulty stick by rotating them
Feb 05, 2009 | Dell Dimension 2400 PC Desktop
Troubleshooting no screen output, please help
sounds like your system is not booting, that may be, obiusly you just have power but that's it...no boot routine. hope somebody else could help on "how to make sure your system can boot again, then the rest.
Dec 23, 2008 | ASUS A8N-SLI Motherboard
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
System panal connector
make sure you have the correct connectors installed from the powers upply to the motherboard. what brand tower do you have? also is the green light on the mobo on?
Jun 21, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Power LED on but no boot up
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Rosewill TU-155 BLACK 400W ATX Mid-Tower Case Logo
129 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
