Question about Water Heaters
Ground floor flat with vented cylinder.
I live on the bottom floor of a two story block of flats.The cylinder was replaced but dont have any pressure on the hot water side.its prob the most simple boiler in the world but the gravity is not enough to push the water to the taps.can a pump be fitted or is there a easier solution?
  • Steve Archer May 11, 2010
    I need clarification
    if this is a water heater it supplies pressure from the incoming cold water there is a valve that lets the water in and should be open
    if this is a boiler then this is more complicated
    some have circulating pumps and others create steam that condensates then flows back in water form
  • 332 Answers
Clean the screen off on the hot side of the heater or the cold side depending on the unit on the shut offs there are cap screws and if you shut the water off and remove the cap screw there are filters inside take them out and clean them
Posted on Jun 06, 2009
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
I own a Rheem Power Vent with powerglo ignition system - model # 21 vp50-1 50 gal, serial # rn 089d06577 ---i've noticed water on the floor around the water heater, i thought maybe the tank was rusting out...
The plastic drain valve is a possibility. Also the Temperature/pressure relief valve is typically piped close to the floor if there is a drain near by. People tend to ignore water heaters. The TPR valve really should be excersized annually. If it won't re-seat, then it should be replaced. Second the tank should be partially drained annually to drain any solids that have accumulated in the bottom over time. If you don't do this frequently the drain valve can become almost impossible to operate.
Aug 05, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I haye a power vent hot water heater that wont light . the fan continues to run what could be wrong
The problem is probably in the pressure switch. The switch is usually a round thing with a hose or two going to it.
You must figure out though if the vent is blocked or if the switch is bad. Check the vent outside to make sure that air is coming out. If no air or little air is coming out of the vent then your vent may be blocked and the pressure switch is keeping the burner from coming on because of that. If air flow is okay then the switch is probably bad. Replace the pressure switch.
Mar 26, 2010 | Water Heaters
Central heating circulating pump
The vent pipe should be in front of the pump so that the pump pushes towards the vent pipe NOT sucks from it. I hope this vent pipe is part of the heating system and not of the hot water
Pumps like to push not pull and therefore it is better if the pump is located further down - say at the bottom of the cylinder or lower.
With an indirect cylinder, the hot water & heating are separate circuits and are not and must not be interconnected. You will need a separate pump for the hot water which should be taken from the hot pipe coming out of the cylinder. You may get vacuation in the cylinder - then you will need an Essex or similar valve to replace the hot water outlet connection
By the way - The pressure at any hot tap is directly related to the height difference between the tap and the header tank in the loft [thus a shower downstairs feels stronger than one upstairs]
Sep 03, 2009 | Grundfos RCP-96 Recirculation Pump for...
I dont know what the problem is so I need a bit of advice. I live in a 3 block council flat and have been here for 2 years. I have NEVER once been able to take a shower as everytime I lift the shower head...
wow , i've been a plumber for fifteen years never heard on like that before, but it should be pretty simple tell them to add a pump to the hot water systeme a taco 007 to be exact if you where in rhode island i could fix that for you. when you add a pump you must turn the mixing valve up hotter a little to build enuff pressure. hope it works out.
Jan 04, 2009 | Water Heaters
Upstairs rads r cold appears to be no pressure 2 vent rads
you have air lock in top floor rads must bleed it out start with the one closest to boiler and work your way out to what you figure is the end of line as best you can figure
Dec 03, 2008 | Water Heaters
No hot water
need more info please
Oct 25, 2008 | Water Heaters
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
