Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Small spot on screen
While tv is on, be it a tv picture or playing a dvd,there is a little spot half the size of a pencil eracer almost looks like a whole in screen(no hole) i cleaned the screen with the special solution and cloth thinhing the little cherub splashed something on the screen did not help
  • 2 more comments
  • leemoyanld Jan 09, 2009
    the color of the hole is greenish
  • leemoyanld Jan 29, 2009
    thank you tvdave for the help sorry it took so long for reply,yes the hole is the bluish green allthough it is smaller than i indicated little bigger than a pencel lead,if it is burn in the crt tube how did it happen and can i prevent this in the future.
    thank you
    leemoyanld
  • David Friedel May 11, 2010
    When you say "greenish" could it be a mixture of blue and green?
    If so, this would indicate that it is a burn spot in the red crt. The absence of red would make the spot color blue/green
    Is the spot a particular color, or is it black?
  • 90 Answers
There is really nothing you can do to prevent this. For some reason(unknown to me) the crt apparently arced at some point and burned the phosfor in the tube. This could happen due to carbon build-up inside the tube, but there is nothing you did or can do to prevent it. It could be just a fault in the tube. Sorry, but you are stuck with the spot unless you replace the crt. I have seen this in older Hitachi and Zenith sets. Sometimes all three tubes arc and you end up with 3 different color spots.
Posted on Jan 29, 2009
  • 133 Answers
You have dust on your projector, you should be able to take the screws out around the screen, lean the screen away from the tv, and wipe dust off the projector
Posted on Jan 09, 2009
After watching tv for several hours i suddenly lose the picture, but i still have sound
hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Mar 01, 2015 | Samsung LNT4665FX 48 in. LCD TV
Samsung PN43D490A1 has sound no picture need service manual
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Jun 23, 2014 | Samsung LN-S3251D 32 in. LCD HDTV
Why is there sound but no picture ?
jim
May 23, 2014 | Samsung Ln46c530f1f
Voice but no picture.
jim
May 21, 2014 | Samsung LN46B650 46/49.5 in. LCD HDTV
Picture is bad only lines and colors but suddenly some pictures appear and go. what is the prob.lem an soluiotn??
jim
May 19, 2014 | Samsung LN-T4671F 46 in. LCD Television
Why dont i have a picture?
jim
May 18, 2014 | Samsung LN Televison & Video
Samsung LN55C650 picture is dim on the right side
Hi, this sound like the same fault as i had, our tv only had half the screen go off also, the right side, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
May 16, 2014 | Samsung LN55C650 TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Sometime i get an error message on my nikon d90 (lens not attached)why?...i found that by detacching the lens and attaching back fix the problem but i wonder why does that? ps...forgive my spelling
the contacts on your lens or camera may be clogged , just use a pencil eracer rubber one, not syntetic and try cleaning the contacts. look for small black spots ,that can be only removed by a razor.
Dec 22, 2010 | Cameras
Everything seems to be zoomed in a little
It sounds like Ratio problem. It should be a button on your TV remote and or Cable TV box that will allow you to set the picture size to 4:3 Ratio, 16:9 or FULL Look at your manuals they use sveral terms, sometime they use picture, Zoom or Ratio.
Best of Luck
www.aaatvservice.com
Nov 11, 2009 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
95 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
