Question about IBM ThinkPad T21 Notebook
IBM T20 start up problem - CPU fail
Hello, on my 700Mhz T20 firdt the clock stated running slow [changed battery - the same] then would not boot beyond IBM screen. Some Error codes indicated motherboard as suspect. I fitted NEW one, but not CPU - fitted original. This ran perfectly for a few days BUT clock still ran slow, switched off normally. Next start up just IBM screen, no error messages, no BIOS entry etc! I cannot believe a new [not s/h]motherboard has failed so I wonder if the CPU is dead? Any ideas very welcome, and where can I get another CPU - i assume it must be another 700mhz one?
Thanks
  • 520 Answers
Update or reflash youre bios(eeprom)
you can download the program off the net.
search for bios firmware....download the software ...write it to cd..reboot with cd in drive , software will flash bios ...remove disk ..reboot.
Posted on Jan 26, 2009
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
Ibm think pad r32 0196 critical low-battery error will boot up then turns it self of
Fail safe in the battery has engaged. See if the computer will start without the battery, using just the power supply. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery. Also change the CMOS battery inside the computer
Change the CMOS battery
Nov 04, 2009 | IBM ThinkPad T20 2647 Notebook
IBM T20 hard disk won't start, no display, and beeping
it may be drive issue,:
- replace the hd and cmos battery,
- change boot device priority in BIOS
to 1st: cd/dvd
2nd: hd
3rd: floppy or network boot or usb-boot
- exit BIOS saving changes: yes
- reboot from windows cd-rom for testing the cd drive
- try booting from new hd (if bios recognizes it,
then install operation system
- if still the same prob, see a technician about this issue
Jun 13, 2009 | IBM ThinkPad T20 Notebook
Laptop Not booting - No Screen
Clean your memory card, or reseat it. Clean the edge connector with soft eraser if reseating doesn't solve it. Do this when battery is disconnected, completely turn off and no other power supply is connected to it. If not maybe ram failed already. This is the first step before going to anything. For additional instructions try to find it in youtube. Post us some update.tnx
Jun 06, 2009 | IBM ThinkPad T20 2647 Notebook
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Stuck at IBM Thinkpad Splash Screen
Sound like a memory chip has failed. Try removing the memory, I believe these have on board, but not sure. If it doesn't have on board, you will need at least one chip in. If the problem is still there, try removing the CD drive, occasionally they can cause a no start. If it's not the memory or the CD drive, then try a bios flash. You will need to create a bootable disc from IBM's support site using a different machine (obviously).
If the bios flash doesn't fix it, them the problem will lie with the motherboard.
Jun 27, 2008 | IBM ThinkPad T20 2647 Notebook
Thinkpad T20 no boot
TRY TO GO OLD SCHOOL AND USE A WIN 98 SART DISK OR TRY TAPPING F8 ALOT DURING START UP AND SELECT STEP BY STEP START
Dec 19, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
i know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Dec 17, 2007 | IBM ThinkPad T20 2647 Notebook
Can i change graphic card on my old IBM T20?
Good afternoon, Yan!
Wish I could give you better news, but unfortunately, the video card is a part of the motherboard and not replaceable.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 10, 2007 | CMB T43 750 Notebook
IBM ThinkPad T21 Notebook Logo
249 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
