Question about LG Studioworks 700S 17" CRT Monitor
I need to get to my factory settings SVA model # 9005W-B
We moved the monitor and somehow the colors are messed up. HP can't help, can you? what are the % blue,red,green need to be on?
  • mike fischer
    mike fischer May 11, 2010
    Are you sure you did not bend a pin plugging it in?
    Monitor Mike
  • 528 Answers
Just set all of them to same value (80 or 100).
Posted on Jul 30, 2009
How do you factory reset this?
under my computer you will find the tab. Be ab solutely sure because you may lose data.
Sep 08, 2013 | Generic 19" sva 9005w-b widescreen lcd...
Sva monitor model 2400w-bd. have two set up and one keeps going to a black screen after a few min of being on. turn power off and turn back on and screen returns. this is a constant and very annoying...
Your monitor is suffering an overheat condition due to the switcher internally working too hard and overheating, shutting down the switching supply. Replace the electrolytic caps on the board with new low esr ones and you should see this problem go away.
Sep 25, 2011 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Damaged power cord
The power supply AC adapter power cord is the same as used for PC power cord, local PC repair shop should have them.
Or you are looking for the AC adapter is 12v 4A power adapter, try Ebay
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | SVA-USA 9005B (Black) Monitor
Help me
I would try to reset to factory settings first see if that does the trick these are specific instructions for a pavilion vf52 lcd, i imagine they are the same across the board....try it and see how you get on
Adjusting the Factory Recall To recall factory settings back you should follow the steps below: 1 Bring-up the OSD “Main Menu”. 2 Use the ‘+’ or ‘—’ button to move (forward or backward) to the factory recall icon and highlight it. 3 Press the ‘Select’ button to activate the factory recall action.
hope this helps, let me know if i can be of further help
Nov 05, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Color are messed up white is pink
Is it messed up if you plug in an external monitor? if no then something is messed up in the internal connection in the computer and you would need to take it apart and replug in the video cable on the back of the monitor panel.
Jun 14, 2009 | HP Pavilion dv6000z PC Notebook
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Sound worked and now it dont
The sound for this monitor is connected with the usb cable that is attached to the monitor cable. Replace the usb cable from the pc to the monitor.
Jul 24, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
SVA Monitor stuck in Analog Mode or Sleep Mode
Actually it was quite easy. I rebooted my computer in "safe mode" by restarting it and pressing the F8 key. At the start up windows gives you an option to toggle down to "enable VGA mode" and select it. After that, my computer recognized my monitor and it has worked fine ever since!
Mar 09, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
LG Studioworks 700S 17" CRT Monitor Logo
108 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
