Question about Philips 20PF5120 20 in. EDTV-Ready LCD Television
Sound, but no Picture
I am the owner of a Philips 20" LCD TV. Model # is 20PF5120/28. One day, it stopped showing the picture, but it still produces sound. I have it taken apart from the frame, and I can't see any bad connections on the inverter. My question is how do I tell if it's a backlight or the inverter that's malfunctioning? It looks like it has two lights, so I'm guessing it's the inverter, but when I google the part number that's on what I assume to be the inverter, I get nothing. It shows in a square frame "94V-O", "E232940", "JVE 0608". Then beneath that, it shows "DAC-16T003 AOF", "2994743002", "REV: 00 A". When I search for inverters, I get pictures of long skinny boards, but mine is a more rectangular board. Can someone help me diagnose wether it's the bulbs or the inverter, and lead me to a website where I can find parts for this TV?
  • mpofnc May 11, 2010
    I am having the same problem. Do you have any idea what may be the issue or do you have any sugguestions?
SOURCE:
  • 2337 Answers
SOURCE: Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 20, 2008
  • 44 Answers
SOURCE: Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 10 Answers
SOURCE: No picture on Philips LCD TV
One very common problem encountered on many Philips models, old and new, In some cases, the SSB board has to be replaced as the resistor on the PCB on the back of the CRT had to be fixed. In other cases the Y Sustain board had to be replaced. If the problem is not due to these two issues, then the capacitors will need to be replaced as they only have a fixed guaranteed life. Thus, it would be wise to take out an extended warranty on Philips due to this common repair issue which often occurs after the limited warranty has ended. Or you could just call your local repairman. There are lots of websites on how to fix it yourself on google. There could be many reasons. Hope this helps!
Posted on Apr 14, 2010
mace1mace
  • 1138 Answers
SOURCE: my philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
Posted on May 18, 2010
  • 63 Answers
SOURCE: Philips 42PF9630A/32 Plasma TV RED led blinking 7 times
Are there any blown caps on the PSB-power supply board. Most sets have sammy boards and they used very shotty caps. If there are no visual clues being a poped cap at the top (X) they simply often do vaporize and dry out. The YSUS-Main and the 2 Y buffer boards control the picture OSD-on screen display. Your not getting any of that. So power supply is where you start first. The YBU-upper and the YBL-lower control the upper and lower OSD the Ysus main control both of them. Usually if you have one in the door you have to replace all 3. But not always. If you were to replace any of the boards I would replace the YSUS-Main, or get the board reworked at a pc repair shop that does board level test and repai. Its more cost effective.
Best Regards and Semper Fi
Posted on Aug 03, 2010
CAfter the JVC model LT-42E910 is on for 10 minutes, the picture goes blank/black, but I have sound. I must turn off the tv and turn it back on every 5 minutes to get a picture. The tv is 4 days old.
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
Jul 07, 2011 | JVC LT-42E910 42" LCD TV
Philip 42pfl7432d/37 has sound, but no picture, what is wrong?
Tv turn on now,pictures only flashes few sec. than dies have audio left only?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
May 11, 2011 | Philips 42PFL7432D 42 in. LCD Television
Two days ago my tv stop showing pictures but I can swicth chanels, iIcan hear sound but can not see anything. Can you tell me why and should i do?
Now tv turn on,the picture flashes a few sec. than picture dies and only have sound left?Yes,than the tv have 1 or 2 long boards,that are call the LCD inverter boards are dead.These long 1 or 2 LCD inverter boards job are to provide a backlight to the LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Mar 28, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have a philips lcd tv model 42PFL7332D/37. Suddenly, the picture lost, but the sounds works perfectly. Can anyone help me to solve this problem?
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Nov 29, 2010 | Philips 42PFL7432D 42 in. LCD Television
I have a Magnavox 30mf200v/17. When I turn it on the sound works but there is no picture.
Turn the tv on now,have pictures only flashes a few sec. than pictures dies,than have sound left only?Yes,than tv have those 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 30, 2010 | Philips Televison & Video
I bought a phillips 32 flat screen 5month ago,and it has gone wrong,it works for 20 mins then the picture goes off the sound stays on
Tv is less than a year old call Phillips for warrenty repair.This tv have a 1 or 2 long boards,call the LCD inverter boards,it have problems,about to died.These 1 or 2 long LCD inverter boards are to help the LCD screen to have a backlight to produced a picture.That why u have dead pictures,but still have sound.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Sep 20, 2010 | Philips Televison & Video
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 37pf7320a/37 picture issues.
control boards on LCDs and PLASMA tvs are causing no picture , missing area , and other wierd symptoms , it will need to be tested to determine the true problem
Sep 20, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 20PF5120 20 in. EDTV-Ready LCD Television Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
