Question about Whirlpool Dryers
Dryer quit running
The light comes on in the dryer, and the timer works but the dryer does not run.
  • 198 Answers
Check the thermal fuse mounted on the exhaust duct of the dryer. Rear panel must be removed. Thermal fuse has 2 wires and is white.
If you connect the wires together and the drywer runs then you will need to replace the fuse which is non resettable. Part number is 3392519.
Posted on Jan 07, 2009
Dryer just quit. When trying to start the dryer u could here a clicking noise coming from the timer. Replaced timer and now it want make any noise when u try to start it.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Dryers
Dryer runs but does not heat. It runs continually
If your dryer never quits on its own, then your main selection switch may be bad. Even if the clothes don't dry, the timer should still only run to the end of the cycle and then stop. The problem with the lack of heat could also be caused by a bad timer switch, but that is rare. Usually it is caused by a bad igniter/heat sensor unit. Sometimes you can use a piece of sandpaper and clean the carbon off of the sensor and then it will sense heat when the pilot flame starts, then it will let the gas valve send gas to the main burner. The heat sensor it the part that is in the flame of the pilot light.
Jun 11, 2010 | Roper RGX4634KQ Gas Dryer
Dryer will not start. I have power because the inside light comes on . The timer works .
Make sure the motor is not running when you try to turn the dryer on, they are very quite.
If the motor is running then your problem is a broken belt, or the belt has slippled off the motor pulley or idler arm pulley.
If the motor is not running then the problem could be the start switch or the timer switch even tho it is running they can have bad contacts.
Sep 27, 2009 | Whirlpool Dryers
No light and stopped running
check the thermal fuse on the blower housing it may be opened(blown)
Apr 12, 2009 | Dryers
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
157 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
