Question about NetTV DTV34XR 32" TV
I was given a nettv and t did not have a remote. i need to find a code for my remote. this tv is model IS CT1860 REV.NUMBER 1380
What if you dont have a remote
Setup code to check with Magnavox TVs are,
1049 1132 1232
1057 1374 1365
1366 14151144
1206 1364 1317
1287 1194 1289
1142 1008 1383
1061 1051 1278
1262 1130 1233
1172 1053 1380
1046 1027 1053
1054 1350 1160
1155 1298 1025
1231 1238 1481
You have to check out, which brand remote control have any among these setup codes to Magnavox, and buy that remote control. There are several brands remote controls will have set-up codes to Magnavox. If you wish to get detail about which brand remote control should be bought, try the sites linked here, and check. Setup code list, and setup procedure to many popular brand remote controls are given. If you wish to buy an original remote control, contact the authorized service center for Magnavox.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 07, 2013 | Philips Magnavox 27MS343S 27" TV
I bought a oneforall universal remote but need a code for a supersonic 1380
If you are a user of AT&T Uverse remote, your technician might have possibly programmed your Sanyo TV remote before leaving.
If your remote is not programmed you can easily program it by following steps which will be mentioned in the user guide, these include:
  • You must know the four digit code for AT&T Uverse which might have been given to you at the time of TV set up.
  • The remote control codes for Sanyo TV AVM - 1337U are 1045, 4062, 1095, and 1380.
There are different methods to make your Sanyo TV remote work. For example, if you have a black remote, press the zoom button which will be on the right hand corner of your TV. Then you will have to press fast forward for two seconds or till the time the TV shuts down automatically. Then once again switch on the TV and press zoom, your remote will start working once again.
In case you have a silver colored remote control, enter code 922, you will be guided to a menu. You must select RCA. IF code 922 does not work for you, enter code 1041.
  • Any of the codes mentioned in your user guide book will definitely work. Once the code is accepted by the TV, you can program it easily and set the channels of your choice.
  • While setting programs you can program it either the manual programming method or the code search method.
  • Device codes assigned to the TV will again be mentioned in the user guide booklet.
  • The Uverse remote control is a universal remote control which is user friendly.
  • These programmed remotes are configured to work with other audio and video devices too. Uverse also offers other services such as high speed Internet, cable TV service, home phone, etc. It's rated as the best service provider in the market.
Audi Air Intakes
Jun 07, 2012 | GE Televison & Video
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I have a toshiba regza hd ready flat screen tv. Need to program the sky remote for it but do not know the model number. Can't find it on the tv anywhere or find the manual! Any ideas on how I could find...
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Nov 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Hi there i need code for sky remote to pair up to samsung lcd tv model number LE40b652,have tried 0060 in the book but not working sky bloke said that there is a tv model number code
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Feb 28, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Televison & Video
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
NetTV DTV34XR 32" TV Logo
37 people viewed this question
Top NetTV Televison & Video Experts
Are you a NetTV Televison and Video Expert? Answer questions, earn points and help others
