Question about HP 1010 Plain Paper Inkjet Fax
Fax problems my fax machine will not print incoming faxes or print copies
  • Anonymous May 06, 2008
    phone line and fax line connected two the same jack however i still can't receive or send
  • Anonymous Jun 26, 2008
    new cartridge installed
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Here is the manual go to hte troubleshooting section
http://www.retrevo.com/s/hp+1010+manual
Posted on Dec 12, 2007
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP 1010 Plain Paper Inkjet Fax Logo
157 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
