Question about D-Link DI 514 Wireless Router (DI-514)
MY INTERNET WAS DONE AND CALLED COMCAST TO RESTART AND THEY TOLD ME IT WAS MY ROUTER THAT NEEDED TO BE RESET, THEY TRIED TO RESET, AND THERE IS A CONNECTION THERE BUT NOT WITH THE ROUTER HOW CAN I FIX THIS
Hi
Connect the modem and the router. Make sure the cable from the modem goes to the internet port in the router.
Reset the modem.Resetting the modem can be done by using a paper clip and insert it to the reset hole found on the back of the modem. Restart your router and systems.
Check if this resolves your issue. Post your results.
Thank you
rakesh
Dell Laptop Expert
Posted on Jan 07, 2009
My IPAD 2 will not connect to the internet, ir picks up the router but will not communicate
In settings go to reset, network settings.. Make sure your router IP leases rent all assigned, set them for a 24 hour lease time.
reset your router with a 30 second unplug. imthemobile guru
Aug 07, 2014 | Apple iPad 2 Wifi 16GB
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
Dec 01, 2009 | D-Link Vonage-enabled Wireless Router...
Unable to get wireless connection at a new location
Hi...
Verizon uses PPOE(point to point protocol over ethernet) and Comast does not use PPOE. Therefore she needs to get inside the router 168.192.1.1(user:admin & pdw: admin) to disable the "PPOE". Oh and also, the router needs to be hard wired to the computer for reconfiguration to take place...hope this helps
May 18, 2009 | Linksys Wireless-G WRT54G Router
Belkin G wireless Router
Do you have an all-in-one router from Comcast? For example, do you have the cable (RF) line and your PC plugged into the Comcast router? If so, unplug your PC from the Comcast router and connect the Internet port of the Belkin to the ethernet port on the Comcast router. Then plug your PC into the LAN port on your Belkin.
[PC] ---> [Belkin] ---> [Comcast] ---> Internet
Once you have connected your boxes as displayed above, you will need to power everything off and bring up the boxes in the following order:
Comcast (wait 60 seconds)
Belkin (wait 60 seconds)
PC
If you cannot get out to the internet, momentarily press the reset button on the back of the Comcast box. Comcast routers are weird. A poweroff should reset the router but I have seen a few times where nothing works until the reset button is pressed (this is also recommended by Comcast).
I hope this helps.
Dave Grannas
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
Resetting password ? Bell told me I would have to change my router password
The router has a built in configuration chip that allows you to work on the router from your computer. This is called Web Admin Console
Your computer's IP address is 192.168.10.4
The router's address is by default 192.168.10.1 from factory. (AKA the GATEWAY.. like gateway to the internet) This can be changed but it is highly reccomened you leave it default.
To access the configuration of your router
Go to internet explorer and type http://192.168.10.1 hit enter.
You will see a window with a webpage of some sort that has the Motorola logo somehwere.
Look for PPPoE or password setting... you should be able to navigate from here..
A word of advice.. enter your password, save settings, slick or or something like that..
then restart router (pull power, wait 5 secs, and then plug back in) The router has to talk to Bell for a bit to make sure it knows that you're authorized to use the DSL line.
Best Wishes..
www.techvisitor.com
Nov 03, 2008 | Arris Wireless G Broadband Router (wr850g)
2 wire router and Comcast
Cable from modem gets inserted into router port named WAN/Internet
from router you should have a cable going into back computer ethernet port.
once inserted, input router IP address into an address bar (IE or My Computer) eg. 192.168.1.1 --- to find out what your router I is:
Start > Run > cmd > ipconfig /all --- router ip would be listed as Default Gateway or DHCP server
Once logged into router, go to Properties page of router config and perform a Release and Renew of router's ip
Jun 30, 2008 | 2wire (1000-400108-001) Router
Belkin F5D8233-4 Setup Problems
Hi Erich. Don't rate this til we're done. Do you have DSL connection?
May 21, 2008 | Belkin (F5D72304F5D7000) Router
My Router is out of warranty how do I troubleshoot it?
Hi, the BEFW11s4 sometimes is just a plug and play router. If your internet is working when your pc is connected to the modem, just do this steps.
1:Lets reset the BEFW11s4. with the power on, push the reset button at the back of the router for 30seconds, unplug the power of the BEFW11s4 for 10 seconds.
2:Disconnect the pc from your Comcast modem. Connect the ethernet cable from your modem to the INTERNET PORT of the BEFW11s4. Connect the pc to the BEFW11s4. NOTE; MAKE SURE THE PHYSICAL CONNECTION IS CORRECT.
3.Open INTERNET EXPLORER. ONLINE OR NOT?
A. IF ONLINE, clear the address field then type 192.168.1.1, if it ask you for a username and password, then we are ok. THE ROUTER IS ALREADY WORKING.
B. IF NOT ONLINE, TURN OFF PC, TURN OFF BEFW11S4, TURN OFF THE COMCAST MODEM. WAIT FOR 3 MINUTES
TURN ON MODEM, WAIT FOR 3 MINUTES, TURN ON BEFW11s4, WAIT FOR 3 MINUTES, TURN ON COMPUTER
IF STILL NOT ONLINE. Open internet explorer, type on the address field 192.168.1.1, username(nothing, as in blank), password(admin), click ok.
It will take you to the Linksys configuration page(Purple and white screen. On the screen you can see tabs
SETUP WIRELESS APPLICATIONS AND GAMING
MAC CLONE
CLICK THE MAC CLONE TAB, then click on Clone or Clone your pc mac, the save settings at the buttom. After this try the internet. If still offline, unplug the power of the BEFW11s4 for 10 seconds, try the internet again. It should be working now.
If still offline, do STEP 3B AGAIN. IT SHOULD BE WORKING ALREADY. IF THIS DOES NOT WORK, you really have to buy a new router.
I have solved this exact problem more than a thousand times. It always work if the router is still ok.
Good Luck
Mar 08, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
D-Link DI 514 Wireless Router (DI-514) Logo
29 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
