Question about Panasonic Lumix DMC-FX01 Digital Camera
Lense stuck out ? DMC-FX01
Having enjoyed this camera for just over a year - I was disappointed when the lense extends to full zoom position (x3.6)and declines to budge no matter which buttons I press ?? If I switch mode (via the thumbwheel) to playback mode - only the last picture taken can be viewed and again no other buttons can change anything ? When in 'scenery' mode - the menu is displayed but going slightly mad by self scrolling through the scenery options ? All the other modes have the same problem as the normal mode..ie x3.6 full zoom and I'm not going to let you take a picture .......aahhh !!! I have tried the obvious of battery removal & replace / SD card in/out...............but any other suggestions would be gratefully received......thanks guy
  • junoir Nov 18, 2007
    camera want focus and is telling me to turn camera off then on again.
I had a similar problem with mine. When I turned it on, the camera would zoom out all the way and the other buttons wouldn't respond. If I switched it to review, it would just cycle through all the pictures, so I figured somewhere the zoom lever was stuck inside. I don't know a lot about cameras, so I sent it in to Panasonic (it was still under parts warranty), but was informed that due to "grit substance" my warranty was voided and it would cost $179 to repair. Since I could buy the same camera used at www.keh.com for that price I told them to send mine back and I'd take a shot at fixing it (since I was pretty sure it was a mechanical problem). Here's what I did with a $1.79 glass repair screwdriver and tweezers. Remove the battery and take out all the visible screws on the outside (2 on the right, 1 on the left, 3 on the bottom). Lift the back panel at the bottom edge, and it should pivot along the top edge until you can remove the back. Then unplug the two ribbon cables (the small one has a latch on top and the larger one has a black latch on the side that you need to lift). BOTH have hinges, not just the smaller one like other posts have said. Next you need to remove the front panel. There are three silver screws placed around the lens unit (look down inside, and you'll see them attaching it to the front panel). Remove these, and you should be able to remove the front (lift at the bottom and it pivots along the top edge). Now you should be able to pop off the top cover (with the zoom, power, etc). Now if you look at the bottom, there are two screws holding the board to the cover, remove these and you've got it apart. On the top right side of the board, you'll see where the external zoom switch pushes a very small black lever. This was where the problem with mine was, the black lever was stuck over. You can use the tip of the screwdriver to pop it back to the center position. Now make sure that if you push it one way or the other that it will recenter on its own. Mine didn't, so I had to pop the small silver cover off where the lever is with the flathead tip of the screwdriver. Be careful here. The lever just sits on a peg, and has very small gears that move a slide bar. If either of these fall, you may never find them again. I took both the lever and the slider off, cleaned them, and got it so it would recenter easily again. Then I put them both back in, popped the cover on (you may have to pry out one of the sides slightly to get it back on), and the lever works fine now. I wouldn't be surprised if your camera has this same problem. If it's something else, it's still probably a problem with this mechanism that you could fix. Anyways, reattach the board to the top cover, and pop it back onto the camera. Now insert the battery, and turn it on to see how it works. Even without the screen, you can try the zoom. If it all works, then all you need to do is put it back together in the opposite order you took it apart. When reattaching the LCD ribbon cables, make sure the hinges are open, insert the cable, and snap down its latch. Hopefully that works. I don't know much about cameras, but it wasn't too hard. Just work slowly and carefully.
Posted on Aug 19, 2007
Lenses sticking out or failing to retract fully are extremely likely to be a result of mechanical breakdown or power failures. Assuming that the battery is not flat and the lens still fails to function one can fairly make the assumption of a mechanical failue. Further clues pointing to a mechanical fault are grinding noises coming from the lens or clicking noises; these noises are produced by the small plastic gears and motors that move the lens. Dirt is the probably the number one cause of such failures. Literally a single grain of sand was to blame for the failure of the last camera I fixed. The gears are so small that one grain of sand can jam the teeth and prevent the lens functioning. So what to do? Taking your camera to the shop is likely to result in the shopkeeper telling you that "the camera is totally ruined and the parts are going to be more expensive than the camera is worth and that's without labour costs!" This is partly true, new parts are very expensive and so is the time it takes for someone to fix the camera. It's worth having a go at fixing the camera yourself, it's a challenge, fun and you'll feel rather smug knowing you've saved yourself a lot of money. Also what have you got to loose the alternative is throwing it away as the cost of repair is generally prohibitive. A source of cheap parts is buying a broken, there a many for sale on internet sites and you can use the broken camera as a trial for dissmantling prior to fixing your own camera. You'll need a quality (its important to get quality tools as they wont damage screw heads) set of prescicion screwdrivers, a magnifying lens, lots of little cups (to save the screws in), some forceps, a fine brush and a good few hours. Start by taking the battery out and then take a good look at the camera so as you can put it back together, you don't need to be an electrical engineer but you do need to work logically, never force anything and be observant. Identify any screws you can see and remove them (anticlockwise to remove, clockwise to tighten). Slowly start to pull the camera to pieces keeping all of the screws in little cups and all of the parts in a well laid out pattern to help you reassemble them. I find working on a large table with a tray is useful. Most cameras are built in a modular fashion i.e. thay'll have an outer casing, a steel frame, and then a lens unit, a screen unit to view the photos, a flash unit etc which are all fited together to give the finished article, in this case a camera. Once the main cover is off the lens unit is usually very obvious and will be a discrete unit with usually 2 electrical leads attached to it and the mother board. One of these leads is for focusing, powering and working the lens and the other is for the photoelectrical unit that converts light into your digital images. Carefully examine the conections and figure out how to disconnect them, it's usually very easy. Now look for any screws or mounting brackets for the lens unit and remove them. The lens unit sould now be very close to popping out of the camera. Once you've got tthe lens unit out you can set to work on it. Using the principles of meticulous obseravation and care dissasemble the lens. Great care should be taken at this point not to disrupt any of the delicate working of the lens, also beware that some components may be spring loaded and may jump out at you. There is occasionally a seperate cover over the gears that move the lens, remove and inspect this, very often sand will get in here and cause the problem. Use a fine brush to sweep away the grains or a needle to pick out individual grains (use some initiative) At the rear of the lens you will find the photoelectric unit. This is the bit that governs the megapixel number of your camera. It is very fragile so treat it with respect. Do not scratch it or touch it, generally try to avoid it! as they rarely break. thoroughly clean the workings of the camera so as the gears etc all work smoothly and hopefully you will have fixed teh problem. If you see a white paste around the gears, this is normal, it is the factory fitted lubricant. Now reassemble the camera, prior to complete reassembly insert the battery and test it, if the problem is not fixed you may need to clean it again or there is another problem which hasn't been addressed. GOOD LUCK, it's not that difficult
Posted on Jul 21, 2007
Had the same problem... zoom switch stuck at full zoom.  Same fix worked.  All I had to do was take out the initial exterior screws and clean with a forced air computer cleaner. The switch released, and all is working well.
Thanx for the tip!
Posted on Aug 01, 2008
My camera did the same exact thing. the only explanation i can think of for mine is that there is sand in the camera. i just went to the beach and was taking pictures. i think the only solution would be to go to a store so they can get all the sand out but i was hoping to figure out if i could do it myself.
Posted on Jun 30, 2007
Have you tried to download pictures using the camera cable? My camera just came up with the same disease and I believe it is with the 'menu/set' button locked up.
Posted on Jun 14, 2007
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
The zoom doesn't go in anymore. The display says SYSTEM ERROR. Please help!
Hi the problem you are having can be down to one of two problems.
the first being that the lense motor has jammed and the second being that the motor has packed up all together.
what you can try is when you switch the camera on does the lense come out on its own if it does wait for it to come out then when you press the zoom button give the lense a little pull and a push doing this will usually free it up.
also try this take the battery and memory card out with the camera off, then hold the camera in one hand and hit it into the palm of the other hand doing this will free the motor if it is stuck.
if after doing the above it still wont move then this points towards the fact that the motor has packed up and no longer in working order.
the problem with this is that the cost of repair would be more than the camera is worth so if the above dont fix the problem then your best bet is to sell it as spares and then buy a new camera with these camera's you will find it just costs way to much to have any work done to them
please let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 01, 2010 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic FX-01 Lens zoom ring (around shutter release) loose on
must to open ur camera and completly open that lense and clean well all gears then fix it back it will work
Jul 11, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
When I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Apr 05, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
My lumix DMC-FS3 Camera's lense is jammed
its toast! I really don't have the full answer other than the part the makes the lens go in and out is broken, needs to be replaced however, it costs more than a new one.
Jan 04, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Zoom lense stuck
The only solution is to replace the lens module.that module is very costly. hope it help
Aug 09, 2007 | Fuji FinePix F460 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
513 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
