Question about Stoves Kitchen Ranges
Top oven coil isn't working on old kelvinator stove
My mother has an old nash-kelvinator stove the top oven coil element has quit working. I need to find a replacement part.
The label on the warmer side says:
Nash-Kelvinator
Detroit, Michigan
Model No. ER 489
Serial No. 340087
Max Watt 12580
Load Watt 12580
Electric Alternating Current
Voltage 115/230-120/240
Any help is appreciated.
Shelley Gallegos
zillbilly002@yahoo.com
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
watugot
  • 290 Answers
SOURCE: Kenmore Electric Stove - Gourmet Edition
Thanks for the numbers.
The 628 in the model# tells us it was built by Frigidaire. The date code in the serial number is less clear because it is a different code than their current serial number designations that have been in use since the mid '80's. The style of the stove makes me think late '70's, I would guess '77 or '78 from the first 3 digits of the serial number.
The thermostat should be easy to check. If the broil function in the large oven works, the thermostat should be ok. It is a simple switch that should read closed across the contacts when you turn it to any temp setting when the oven is cool.
The power for the oven will also go through the selector switch which routes the power to different components depending on the setting.
The power also goes through switches in the clock that allow the timed bake and self clean functions to work.
If there is no wiring diagram in the stove, you will probably need one to diagnose the problem if the thermostat checks ok. I would suggest getting one while it is still available in case you need it in the future.
Once you have found out exactly which part you need, you should be able to use the Frigidaire part number from the parts list on the Sears site to track down a replacement part through a local appliance parts dealer. You may have to take the part to them to try to visually match up a replacement. Thermostats and selector switches are usually pretty generic in their operation between manufacturers, the problem lies in finding one that will mount to your control panel properly and that your knob will fit so that you can keep the same uniform look along your control panel.
Please post back with what you find out or if you have any questions.
Thanks/Mike
Posted on Mar 04, 2008
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
lojacksdad
  • 121 Answers
SOURCE: finding thermostat for Kelvinator model c-7-r
you can go to the parts store and get a universal thermostat very easy to install
Posted on Apr 23, 2009
dmftrucker
  • 1922 Answers
SOURCE: Where can I buy a door for my old Kelvinator Freezer Model KVF121
you can try calling mappliance parts pros, your model # didn't show on their web-site they are at 1-877-477-7278
Posted on Oct 26, 2009
I have an old kelvinator stove ,the burners work, but the oven does not . i'm hoping it has a fuse or circuit breaker that just needs to be reset. ( I had one just like it and the burners worked but t
Some old stoves did have a fuse for the oven igniter. It could be just a bad igniter. Check under the top panel and see if there is a small black cap toward the right side toward the back. If there is one then it is the fuse. replace the fuse and see if the oven comes on. You may still need to replace the igniter. If it an electric stove then the element is probabaly burned out or a wire burned off.
Oct 06, 2014 | Kitchen Ranges
Where can i find my kelvinator stove fuses
Fuses located on the top under panel. Pull the front ends and bring it up. Oven fuse (two of them) separate from burner fuse
Jun 09, 2014 | Refrigerators
How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Jun 02, 2014 | Kelvinator Refrigerators
How to change cooking element on top of stove. is there a detail drawing and manual stove is 4 year old
Electric stove top? Is the element a coil or soild element? Or is it a glass top?
Feb 07, 2011 | Ovens
I need a replacement element (8 inch) for my Kelvinator range (model no. KRS J3L-1)
Hi, W/D here.
Here's the easiest way that I know of to repair your stove:
Remove your element. Most can be removed by lifting the element on the side away from where the leads disappear under the stove top, and then pulling it out of the plug-in socket.
Take the element with you to one of the larger hardware stores, and locate the elements that have your style of terminals. The elements are generic; that's why you needed your old one. I have replaced dozens of elements and have found the generics to be every bit as good as one ordered, and cheaper, too!
Best regards, --W/D--
Jan 31, 2011 | Microwave Ovens
My ge range has quit working. First the stove top (coils) failed to heat up (all at once); then about a week later the broiler coil failed to heat up shortly followed by the entire oven. The 'on' light...
The stove top is internally wired separately from the oven. Check that you don't have a faulty circuit breaker in your breaker panel. The oven is 240V which has two breakers ganged together. If only one side trips you can loose power to the heating elements but still have power to the control board (to light up ON).
Jun 23, 2010 | Kitchen Ranges
My Kelvinator oven is not working. I've checked the fuses and it is getting power. The 4 burners of the stove still work and I'm getting an occassional flicker of the little orange light if a switch the...
Kelvinator oven not heating? How to replace a kelvinator fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for KELVINATOR element How to Repair Home Appliances
May 12, 2010 | Ovens
Oven does not get warm, suspect it is a fuses but cant locate it
It is probably due to a broken heating element in the oven. These are relatively easy to replace. You can test it with an ohmmeter. It should measure low ohms. If it is open circuit then it is broken.
Jul 25, 2009 | Stoves 1100DFSID Kitchen Range
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
262 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
