Question about Sylvania 6313CA 13 in. TV/VCR Combo
Jam the tape is jammmed and the tv will only turn on for about 5 seconds and then turn of what do i do
  • Anonymous Mar 07, 2009
    tape is jamed and tv turns off every 5 seconds
    Sergeant:
  • 308 Answers
This Sylvania was made by symphonic Funai, and you may want to try holding in the eject button while powering it on. The cause of the problem could be anything from a defective tape to a bad gear inside the mechnism throwing it out of time or even a bad/dirty mode select switch. Unless the set is in warranty which I very much doubt, it may not be worthwhile getting repaired. The tape cannot be "forced" out of these machines without getting them out of time and the symptom would be the same as you now have. If it's not that old, maybe you could get Wal-Mart to take it back.
Posted on May 29, 2007
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
TV Starts but then shutsdown
I'm having the same problem, but I have a 13" with built in vcr. It acts like it's jammed with a video tape (it's really empty), and turns itself off.
Feb 16, 2008 | Zenith B25A24Z 25" TV
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Stays on for 5 seconds, thinks it has a DVD or VHS tape in
I am afraid the set has a bad or broken tape transport, or better known as a bad tape carriage.
Jun 20, 2007 | Philips Magnavox 20MC4304 20 in....
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
Sylvania 6313CA 13 in. TV/VCR Combo Logo
89 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
