Question about Linksys Wireless-G WRT54G Router
I can not get to the Ip address 192.168.1.1 to configer the route
What can i do
  • anmiyoto Jan 07, 2009
    I was able to get the IP address 192.168.1.1 earlier until I held the reboot button in the back and now it asks for authorization. I type in username and password but it doesn't recognize it. What can I do?? I was trying to set up wifi earlier before this all started..
    President:
  • 623 Answers
You're almost there.
On some of the older versions of the router, you have to leave the username field blank and type "admin" in the password field.
You can also get the manual here.
Just a note on the wireless security: Try avoiding WEP, because it is not secure anymore. Go with WPA or WPA2 (if possible) instead.
Posted on Jan 08, 2009
  • 139 Answers
Hi
all you need to do is to press the reset button which is there at the back of the router for 3 min. Once you are done with the reseting unplug the power cord of the router and then turn on the router after one min. Your default user id and password will be .........
username - admin
password - admin
and you will definetely get the main page of the router. Once its done it will automatically set the router to DHCP in order to get the ip address. Please make sure that your router is connected to the system.
Posted on Jan 07, 2009
Hey sawad28800,
You need to visit http://192.168.0.1 That is the Configuration/Access Panel. Also, you need the Administrators Information.
Hope this Helped,
Shanne
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Need to change NAT settings. None of the IP address take me to the router config page.
Its simply because this device is dumb (no config) it is just a standard switch no routing aka: NAT.
http://kbserver.netgear.com/pdf/fs105_fs108_install_guide%20.pdf
Jun 12, 2011 | NetGear FS108 Networking Switch
How to config ip to nortel switch
on the Nortel Passport sw
vlan x
ip address x.x.x.x
ip address netmask x.x.x.x
on the interface
ip address x.x.x.x
on the Baystack
it smilar to the cisco sw
pls try and tell me
Dec 03, 2010 | Nortel 2526T-PWR Ethernet Routing Switch...
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
The signal do not going thouth to the router to the computer
Are you saying you are not getting an IP address? If you are, then there is two way communication happening between your router and the computer. Is the router getting an IP address off the WAN? You need to verify this by logging into the router and looking for the WAN setup or status. If both of those are true then you have a config issue either on your firewall or the routers routing table or firewall. Check your computer first to make sure it's allowing traffic from the routers LAN IP address. Then check your router's routing table and the firewall settings.
Oct 28, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Routing
show ip int brief This will show you the available interfaces and type.If you want to create on Fa0/0 for example the config will be as follows:
On configuration mode type
Interface fa0/0.[vlan Id]
encapsulation isl | dot1q [Vlan id]
Assuming you are using dot1q and terminating vlan 200 The config is as follows
int fa0/0.200
encapsulation dot1q 200
ip address --------
on Gig Port
Int gi0/0.200
ip address
The encapsulation used should match the switch trunk.Default encapsulation is isl on cisco switch.If you are connecting another vendor use dot1q encapsulation.
Dec 27, 2007 | Cisco 2501 Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
