Question about iLO 3200 32 in. LCD Television
The tv died
I have an ILO 28" lcd tv With no sound or picture. We had a brief power failure and when the power was restored the tv did not respond. It is just plain dead. It is plugged into two expensive surge protectors. We purchased this unit from Walmart about three years ago. Thanks, and Happy New Year!
Joe C.
  • 6 more comments
  • druiden39 Jan 07, 2009
    An ILO 28" LCD went dead after a power failure. The tv was plugged into two power surge protectors. It now has no sound or picture. If this is caused by a blown fuse (?) where is the fuse located?
    I have a ILO 28" LCD tv that died. I have it apart and the PC boards are exposed. I can't find the fuse. Where is it located, and what does it look like? Where can I get a new fuse?
    What do the fuses look like
    I need to know what the fuses look like.
    I have checked the power cord and voltage is getting to the tv. I need to know what the fuses look like.
    I have this TV apart and the PC boards are exposed. I have checked to see if power is being supplied to the TV. It is. I need to know the location of the fuses and a description of what they look like.
    I need to know what the fuses look like. Can anyone give me a description of them and there location. The TV is apart and the boards are exposed....
    It looks like I'm getting nowhere fast....All of the questions were not answered and were somewhat contradictory. The last bit of advice made no sense at all!
  • 716 Answers
My ilo Does This Every time We Have A Power Outage Did You Reset It????? Unplug The Tv And Hold Down The On Off Power Button For 30 Seconds Then Release And Plug It Back In And Check.
Posted on Jan 07, 2009
    President:
  • 846 Answers
1. Take it to a shop, TV's like PC Monitors are dangerous to work on if your unfamiliar with them. I'm guessing the warranty is out on it since its 3 years old but you would probably only pay for a diagnostic fee.
2. If you have the info on your surge protectors most of the more costly ones have guarantee's on them to protect your equipment. I don't know how hard it would be but you could eventually get them to pay for repairs or a new TV in the end if worse case scenario.
    Sergeant:
    Champion:
  • 435 Answers
Hi, Fuses normally look like transparent cylinders like this. http://profesanxenxo.iespana.es/electrical/fuse.jpg
If its bad, you can see it burnt out. Or you can also check w/ a continuitiy tester or a multimeter.
    Brigadier General:
  • 5,158 Answers
Despite all that wonderful advice... is there a circuit breaker on the surge protector... reset that
Robert
    Genius:
  • 1,239 Answers
HI
check the backlight or have a pro check it.
    Genius:
  • 2,920 Answers
From the sounds of it you got hit by a power surge and with all these people telling ou to replace this or that you dont know whats going to help if anyting.if yo really want to now if it can be fixed take it to a shop and have them look at it and tell you exactly whays wrong and what needs replaced if it can even be repaired. alot of times they cant be due to the internal damage to them
    Sergeant:
  • 233 Answers
Fuses may also be the PICO fuse style, Pico fuses look like small surface mounted components usually tan or orange in color- use a meter to check the fuses, as you cannot tell by looking at them.
    Genius:
  • 1,199 Answers
Replace power transformer!
  • iLO Master
  • 19,396 Answers
Surely it can be a fuse, that is an obvious consideration, but I dont think that going for fuses on power board is a valid approach. Tere are many power boards here, surge protector and TV, and you do not go straight and open the TV to check the power board.
Unplug the surge protector, and try the TV straight on a different socket, after leaving Set unplugged for ten of twenty minutes.
If it still does not start then surely the power supply had a problem,
Few ILo have external power supply, in this case you can just replace the adapter.
If the TV does not have external PSU, then the PSU board had something that has blown.
In there there is no fuse that you can just pull out, but a resistor soldered on board or a capacitor that has blown.
Here you can find replacements.
Ilo power board.
Find parts here (thnks for pics).
    Scholar:
  • 76 Answers
Try plugging the TV into a outlet without the surger protector to see if its the problem, there may also be a reset and/ or unplugging the replugging it in to reset it.
Most surge protecters will come with a warranty against damage to componants.
If your LCD is getting power and you'd like to check for a fuse inside I would guess this would void the warranty if it's not done by certified technician. I would proceed to getting re-imbursed for your lcd from the surge protector mfgr. first
Good luck, let me know if this helps
    Novelist:
    Scholar:
  • 67 Answers
Before you try to open the tv up and change a fuse, you might want to try plugging the TV directly into a known good outlet to see if the power strips may have been tripped by the surge.
Even when other devices plugged into the surge protectors work, it doesnt mean that that particular plug it is occupying may work.
Try that and give us some feedback.
    Genius:
  • 1,550 Answers
There will be around 8 fuse which you need to look at . Four will be in and around the power board circuit . The remaining will be around the Main board .
  • 679 Answers
Tell me did you plug any headphone or any audio device to your TV?
  • rockfixya
    rockfixya Jan 07, 2009
    fuse is located inside the TV, on the main board.
    Sergeant:
    Champion:
  • 304 Answers
have you try plugging the powercord into a different outlet?
as a the power failure happens, the power supply of the unit might have the problem.
  • Elizabeth Krijt
    Elizabeth Krijt Jan 07, 2009
    check and test if the problem is on the tv, outlet, or in the surge protector.
    Sergeant:
    Scholar:
  • 199 Answers
Most probably the fuse is blown in your tv to avoid the further damage there is a fuse in the tv on the main board that blows out.and it needs replacement.the cost of a fuse will be near to $2.
  • iLO Master
  • 13,433 Answers
As this happened on a power surge a fuse may have blown.
  • Ekse Jan 07, 2009
    That would be best documented in a service manual, but I suspect the fuse is on the power board close to the power plug.
  • 3,037 Answers
Hi druiden39
Sounds like the power supply on the tv is fried. Is there power to any of the components of the tv besides the power supply? It is possible that the surge protectors didn't work. Check for voltage on the other boards and if you don't get any then I think the power supply is fried for sure and you need to replace it. let me know if you have questions with checking this.
bestdarngood
  • 4,806 Answers
Hi there
Check the fuse at the end of the cord the plugs into the wall, if that is not problem you will have to open up the TV and have a look at the main power board for the blown fuse.
Good luck and kind regards
ILO DPD4210, no picture or sound. It appears to be stuck in stand by mode. The LED lights are solid Green or Red. It just stopped showing the picture and sound. Any suggestions of what might be the...
Sounds like an ordinary power supply failure. You just have to desolder and semiconductors that are bolted to heat-sinks and or look for electrolytic capacitors that are bulged or not the correct reading. A lightning strike or power surge could have blown a thermistor.
Oct 17, 2013 | iLO 3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
I need to find out how to change the lcd lamp
LCD tv don't have any kind of lamp,only have 1 or 2 a long LCD inverter boards,help the tv LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay,com to buy those 1 or 2 refurbishes long LCD inverter boards for the replacement.If ur LCD tv have a picture only a few sec. and died,than have sound left only?
Nov 23, 2010 | iLO LCT32HA36 Television
TV wont' turn on
The failure on your LCD is due to a defective power supply. Leaky or dry capacitors is the reason for the failure. Replacing or repairing the power supply should fix your LCD.
Contact this website and ask them if they have any power supplies in stock.
Good Luck.
Sep 04, 2008 | iLO LCT32HA36 Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
I have a ilo 32-HD lcd tv
I have the same problem with mine. Screen was gray but I had sound. Nothing I tried worked. I bought a new TV and the Ilo is sitting in the junk room till I find a solution or get the ambition to take it to a shop to get checked out.
Jan 16, 2008 | iLO 3200 32 in. LCD Television
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
My Ilo flat screen tv just stopped working
phll[atric
i was watching my ilo last nite. turned it on this morning and nothing . Please tell me what to do. puzzled?????????? in dc
Dec 18, 2007 | iLO V27DMBX Television
iLO 3200 32 in. LCD Television Logo
451 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
