Question about JVC AV-30W476 30" TV
Cannot get low channels - but can get high channels
When programming the TV I can bring in channels 48 and up but when I try to get channels 2 to 47 all I get is a blue screen. No picture or sound. Have tried adding the channels but it still doesn't work. Worked fine before turning it off and when I turned it on, it was like that. Is it something in the remote I hit by mistake? I've gone throught the menu and try and find something and nothing helps it.
  • Barbara Winters Jun 01, 2007
    Had the remote checked out and it is fine. They said it could be in the tuner.
    Don't have it fixed yet, but am going to call a repair man.
    Thank you for your help.
    Barb
    Sergeant:
  • 308 Answers
First thing I'd try is disconnecting the AC power for about 30 seconds then plugging it back in and recheck the symptoms. You may also have corrupted data in the EEPROM (a memory chip that holds the channel frequencies and other information the set needs to operate) which would mean a trip to the repair shop. Otherwise, the tuner would be my last bet for this symptom, another shop repair. If the first choice didn't fix the problem and you have picture-in-picture capability with two tuners, you might want to switch the cable to the second tuner stub and switch in the menu to that tuner to see if that works around the problem. If you were using a cable box, of course that would be where the problem lied.
Posted on May 29, 2007
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
I tried auto programming my tv but I can't go past channel 69. All other tvs go up to at least 99. When I try to manually program 99, the remote will only input a 9.
There are only a possible 48 channels available in the UHF bands IV and V; 21 - 68. Some Continental TV's still use band III; 1 - 20
Are you sure you are not getting confused by programme numbers which can go up to 99 and AU etc.
Jan 04, 2011 | Panasonic CT-27E13 27" TV
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Static on all cable channels
The tuner is questionable The problem lies inside the isolation box. Ask a repairman to open this isolation box and resolder the small board. There are two small resistors that need resoldered. This also has the rf connector on it. And you may have him resolder the tuner if this does not fix it. Have him inspect any and all grounds on the main board as well. Good Luck
May 31, 2009 | Toshiba CF32F50 TV
Cannot program all cable channels into tv.
is it keeping low channels or high channels because you have diffrent tuner bands may be eeprom also
Apr 03, 2009 | Televison & Video
Channels
the only way i could fix the problem was to hook up a vcr to the tv and go through the channels that way so if that helps anyone theres the solution
Jan 05, 2009 | Televison & Video
Sanyo ds25830
There is a button under the bottom edge of the screen (with the controls) that has the options "Normal" and "CATV" - press this and it should solve your problem.
Tracey
Feb 23, 2008 | Televison & Video
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
Tv only has select channels
If you have a good cable signal connected to the TV and it receives channel 50 nice and clear but all lower channels have nothing but snow, then the tuner is defective and needs to be replaced. This is quite an easy thing to correct. Sometimes resoldering all connections inside the tuner will bring it back to life, but in either case the set should be serviced by a qualified tech.
Aug 23, 2007 | Toshiba 36AF43 36" TV
TV sound problem
Hi Mah, It sounds to me that the tuner in the TV has drifted off tune. Your problem may be solved if you can bring up on the screen the channel bar which goes from 22 to 69, then `scan for channels'. saving the good ones and passing over the poor ones. Also selecting the program number before you save each channel. I do not think anything is wrong with the sound circuit.
Oct 22, 2006 | Goodmans 289NS 14" TV
JVC AV-30W476 30" TV Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
