Question about Dell Latitude D800 Notebook
Internet connection when my laptop goes into hibernation or stand-by mode it loses internet connection. In fact it won't recognize my modem and router until I re-boot.
Hi update your wireless card driver and bios by downloading from
here.
http://tinyurl.com/axacgx
And also post your router and modem brands and model number
Thank you
rakesh
Dell Laptop Expert
Posted on Jan 07, 2009
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
Have a great wireless signal but cantgetonthe internet. It says " page cannot be displayed, cannot find server or DNS error Internet Explorer"
I suggest doing a power cycle of your modem and router.
Unplug your modem and router.
Then plug your modem back in and wait for it to boot up.
Plug your router back in and then you should have a proper wireless connection for your netbook.
Mar 06, 2011 | Sylvania G-Netbook
My Motorola sb5101 won't come online how do I troubleshoot this? My cable connection is fine. When the modem boots up the green power light comes on and stays on followed by the receive light and the send...
These modems are very tricky. When this type modem goes into stand by modem that indicates that you do have a connection to your internet service provider. The reason you cant get online is because all internet access is disabled wile the modem is in standby. If you look closely there is a button located on the top of the modem. This is the stand by button. If you hit that button it should take the modem out of stand by mode and reestablish your connection to the internet.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 02, 2010 | Arris SURFboard SB5101 Cable Modem
Losing connectivity to internet..red light goes on on router
Keep the reset button pressed for 3 minutes.
If you have the CD, try to re-install the same router
If you don't, contact the toll-free # 1-800-2235546
Myself or any other technical support executive will assist you further
Jan 22, 2010 | Belkin (F5D5231-4) Router
On a Dell Latitude - no internet connection
The fact that the lights are on and that you get wireless signal means that the computer is making a connection with the router, but the router is not making a connection to the internet.
Try a sequenced power-cycle. Turn off the computer (completely off, not hibernating or sleeping), then turn off your modem (if you have one) and finally turn off your router.
Wait 5 minutes and turn it on in the backwards order. First the router, then the modem and finally the computer. If it's still not working, contact your ISP's tech support, there's probably an outage in the area or another problem with your internet service,
Aug 03, 2009 | Computers & Internet
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
I have no money to pay the experts My problem i how to confgure the router in to my laptop computer (Blitzz 108 BWA 711)
is this just a simple stand alone, tryin to connect to the internet?
if so -
*unplug your modem and your router
*Connect your modem to your router (Modem output to Router Input/Internet)
*Plug in your modem first and let it boot up for a minute
*Plug in your router and let that boot up for a minute
* now you should be able to see your router in the "network connections"
* once you are connected open a browser
*type 192.168.1.1 in the address bar and that should take you to your router setup, follow your manual
any further problems please Let me know :)
Dec 24, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Dell Latitude D800 Notebook Logo
93 people viewed this question
Alun Cox
