Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Randomly timed popup message re registry
Whenever it chooses to do so, a "Registry Editor" popup appears: "Canot export C:\WINDOWS\temp\CSS_SRC: Error opening the file. There may be a disk or file system error." I don't know what it means and I don't know how to permanently get rid of it (besides closing the popup window).
    Genius:
  • 3,422 Answers
Please follow the instructions from below link to fix the issue:
http://support.microsoft.com/kb/168794
Posted on Jan 07, 2009
  • Microsoft Master
  • 13,433 Answers
When does the error come up? what program is started? do you receive any other error messages?
    Sergeant:
    Scholar:
  • 199 Answers
Its happening because any of the files is miossing from your operating system and needs to be reloaded in the system.
  • Microsoft Master
  • 19,396 Answers
That sounds like a virus, do you have any active antivurus on your computer?
  • Ginko
    Ginko Jan 07, 2009
    The CSS_SRC file is a malaware, many websites that provide cure for it are instead distributing more spyware.
    Use Spybot to remove the problem, and update your antivirus. Do not download any antivirus that you do not know , same for registry cleaners.
    Use this and do a full scan : The home of Spybot-S&D!
How can i fix error 1404 on microsoft office 1010
  1. If you receive the "Error 1404" error message, remove the registry subkey that is referred to in the error message. To do this, follow these steps:
    Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
    1. Click Start, click Run, type regedt32 in the Open box, and then click OK.
    2. Locate the registry subkey that is referred to in the "Error 1404" error message. Make sure that you locate the exact registry subkey that is specified in the error message.
    3. Right-click the registry subkey that you located in the previous step, and then click Permissions.
    4. Under Group or user names, click Administrators, click to select the Full Control check box under Allow, and then click OK.
    5. Right-click the registry subkey, and then click Delete.
      When you are prompted to confirm the deletion, click Yes.
  2. Start Windows Explorer, and then locate the drive:\Winnt\Installer folder. In this folder location, drive is the hard disk where Windows is installed.
    Note This folder may be hidden. If the drive:\Winnt\Installer folder does not appear in Windows Explorer, follow these steps:
    1. On the Tools menu, click Folder Options, and then click the View tab.
    2. Under Advanced settings, click to select the Show hidden files and folderscheck box, and then click OK.
  3. Grant appropriate access permissions for the drive:\Winnt\Installer folder for the following groups: Administrators: Full Control
    SYSTEM: Full ControlTo do this, follow these steps:
    1. Right-click the drive:\Winnt\Installer folder, and then click Properties.
    2. Click the Security tab.
    3. In the Name list, click the appropriate user group or user name that you want to assign permissions for. For example, click Administrators.
    4. Under Allow, click to select the check box for the appropriate permission that you want to set, and then click OK. For example, click to select the Full Controlcheck box, and then click OK.
  4. Restart the computer.
  5. Insert the microsoft office CD into the CD or DVD drive, and then run the microsoft office Setup program.
  6. After the microsoft office Setup program has completed running, reinstall your antivirus software program.
Nov 10, 2010 | Microsoft Office 2003 Basic Edition...
Iam unable to view instant messagas from my yahoo messenger.
1. Exit Yahoo! Messenger by right-clicking the tray icon and selecting Exit.
2. Before you edit the registry, you are advised to make a backup:
a. On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command.
b. Type regedit and click OK. This opens the "Registry Editor."
c. On the "File" menu, click Export.
d. In the "Export range" panel, click All, then save your registry as Backup.
3. In the "Registry Editor," browse down to following location in the registry:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\
4. You should only see a list of numbers under Zones. If you see an unrecognizable character before zone 0, delete that particular key.
5. Close the Registry Editor.
6. Open up Yahoo! Messenger and try to send messages again.
Jul 19, 2010 | Yahoo Messenger
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
My dvd drive is missing how do i get it back i don,t have any discs for my laptop can u help me I need to get directions on how to reinstall fo free i have windows vista home edition
1. Start > Run.
2. regedit
3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4. Select File > Export
5. save the file to the Desktop in case you need to restore it
6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box.
7. Do the same for the UpperFilters line
8. Close the Registry Editor.
9. Restart Windows.
Nov 03, 2009 | Acer Aspire 5100 Notebook
DVD-rom drives lost on two seperate computers at the same time
1. Start > Run.
2. regedit
9. Restart Windows.
Oct 27, 2009 | HP Computers & Internet
Cd dvd burner is not working
Is it not working or not being seen in windows. If you cant see it in windows there seems to be a Windows update or something that is making peoples CD / DVD drive dissappear. If this is what your experiencing then try this fix:
http://icompute.info/cd_drive_not_in_windows.htm
Hope this helps...
Oct 18, 2009 | Acer Aspire 5610-4648 Notebook
Cdwr code 41
To resolve this issue, edit the Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Expand the following registry subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
4. On the File menu, click Export.
5. In the File name box, type backup of drives key, and then click Save.
NOTE: You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved.
6. In the left pane of the Registry Editor window, click the Volume{GUID} folder under Drives, where GUID is a 32-character hexadecimal globally unique identifier.
NOTE: If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive.
7. In the right pane of the Registry Editor window, double-click Drive Type.
8. In the Value data box, type 1 or 2, depending on the drive type, and then click OK.
The drive type should be 1 if it is a CD-R and 2 if it is a CD-RW.
9. Quit Registry Editor.
10. Click Start, and then click My Computer.
11. Under Devices with Removable Storage, right-click the CD-R drive or CD-RW drive, and then
click Properties on the shortcut menu that appears.
12. If the Recording tab is displayed, the drive is successfully recognized by Windows as a recordable
device.
13. Click Cancel.
NOTE: If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps:
1. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose
value you previously changed.
2. In the Value data box, type 3, and then click OK.
The drive type value of 3 indicates that the drive is a standard CD-ROM and is not writable.
3. In the left pane of the Registry Editor window, click the next Volume{GUID} folder.
4. Follow steps 7 through 8 to change the Value data entry to 1 or 2, depending on the drive type.
5. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is
displayed in the properties dialog box of the CD-R drive or CD-RW drive.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
SYMPTOMS
After you install Microsoft Windows XP, the CD-ROM drive, the DVD-ROM drive, or CD-ROM R/W drive may not be visible in the My Computer window. Additionally, there may be question marks on the devices that are listed under CD-ROM drives in Device Manager.
CAUSE
An incorrect device driver was installed for the CD-ROM device.
RESOLUTION
To resolve this behaviour, use the following methods in the order in which they are presented.
Method 1: Remove Registry Entry
3. Locate the following registry subkey:
HKEY_LOCAL_MACHINE/System/Curretcontrolset/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes. NOTE: If this data type is missing, continue to the next method.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit the Registry Editor, and then restart the computer.
Method 2: Replace Existing Driver
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
-or-
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager.
4. Click the drive with the question mark next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action menu, click Scan for hardware changes.
NOTE: If Windows XP cannot locate the driver for your device, the device may not be supported by Windows XP. To see the list of supported devices, see the most recent Windows Hardware Compatibility List (HCL) at the following Microsoft Web site:
SYMPTOMS
After you remove either compact disc (CD) recording software or other software from your computer, your computer may exhibit the following behaviour:
• In My Computer, there is no access to your CD-ROMs.
• In Device Manager, the following error message appears in connection with any CD-ROM device that is part of your computer system:
The device is not working properly because Windows cannot load the drivers required for this device
(Code 31).
• Device Manager displays the following error message:
A driver for this device was not required, and has been disabled (Code 32 or Code 31).
You may also receive an error Code 39 message that indicates that the driver is corrupted.
• Device Manager displays the following error Code 19 message, which means that the registry returned some unknown result:
Your registry might be corrupted. (Code 19)
• You may also receive the following error message:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
RESOLUTION
To resolve this behaviour, follow these steps:
1. Start Registry Editor (Regedt32.exe).
2. Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
4. Locate the LowerFilters value under the same key in the registry:
5. On the Edit menu, click Delete, and then click OK.
6. Quit Registry Editor. NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
7. Restart your computer.
STATUS
This is a known issue that can occur when you remove Easy CD Creator version 5.01 or earlier or DirectCD version 3.01c or earlier. This issue may also occur with Easy CD Creator version 5.01 and with DirectCD 3.01d or later.
MORE INFORMATION
There may be other third-party CD-writing software products that exhibit similar behaviour. Some or all of the troubleshooting steps in this article might apply if such a product also adds entries under the UpperFilters or LowerFilters value in the registry, either by adding its own filter drivers or by removing the registry keys and values outlined in this article that begin with:
Oct 08, 2009 | Acer Computers & Internet
Code 10 cd/dvd
Lets follow this:-
1. Choose Start > Run..
2. Type regedit in the Open text box and click OK.
3. Expand my computer - Expand HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4.On the right hand side, you'll find upper and lower filters, select them one by one and delete.
5.Restart PC and hope it works for you.
Note:Create a restore point before you delete any key from registry.
Thanks
Oct 07, 2009 | Computers & Internet
Can't show task bar in window 98
you could try fixing it through registry
note: before thinkering with the registry make sure to backup your important file a do a full backup of your system registry.
click on Start>Run
and type:
regedit
when registry editor appeared...right click on My Computer(on the right panel)and choose export(this will save a backup copy of your registry) and save it...
now..look for the fallowing registry key and delete it:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\StuckRects
When you restart Windows, the taskbar is automatically recreated.
hope this helps...
^_^
Jul 24, 2008 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
