Question about Whirlpool Metal Guild Drain Kits DC-BLT-20W ; DC BLT 20W Bath and Bar Drain with Lift
Whirlpool waste connection
The instructions say to avoid traps as this evects empteing how do you stop smells coming up
  • 49 Answers
You are correct, you must have a P-TRAP. I believe the instructions are talking about not having an xtra trap between the disposal and the existing trap.
Posted on Jan 20, 2009
How to stop the smell of waste after the plumber fitted our clicker, in April 2017. I asked him about it, but he did not come to fix it. He sent a message.
There is supposed to be a U-trap under the 'Clicker' (had to look that one up) drain. I got $5 that says you no longer have that U-trap. It didn't smell before (evidence you had a U-trap) it only started smelling after the Clicker was installed and hasn't stopped (evidence you no longer have a U-trap.)
The purpose of the U-trap is to keep water in the 'U' so that smells don't come back into the house from the septic whatever.
Get someone else to check it.
Jan 10, 2018 | Plumbing
My new Samsung dishwasher has a HORRIBLE smell
There are 2 possible explanations for this, either the dishwasher has a buildup of food particles and grease in the pipes and pumps and that is starting to decay. Get a dishwasher cleaner and run it through a cycle. You can find several different brands, Finish seems pretty popular, at your local grocery store. The other possible source of the smell is sewer gas backing up into the dishwasher. This happens because the waste water connection from the dishwasher is linked into the pipes under the sink after the P-trap. Take a look under your kitchen sink, locate the connection where the dishwasher wastewater pipe connects to the sink pipes leading to the main stack. Now follow the pipes from the sink drain down there will be a P- trap that prevents sewer gas from backing up into the house, your dishwasher connection should be between those two. If your P-trap is between the dishwasher conncetion and the sink drain then you are getting swere gas flowing into your dishwasher and this is what you are smelling. If this is the case have a licensed plumber come in and reconfigure the pipes so the P-trap is after the dishwasher connection and the smell will stop. It shouldn't take a plumber long and the parts are cheap. Hope this helps.
Oct 10, 2017 | Samsung Dishwashers
A bad odour smell after each wash
check that the gray flexible waste oulet goes as high as it can b4 dropping back down onto waste connection. if the flex comes off your sink trap and drops straight down, food waste from your sink can back up into machine causing smell.
Nov 21, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Can the dryer condeser tank be connected to the waste pipe to drain automatically
Hello
Yes it can, but you need to install a p trap so you dont get a bad smell from the waste pipe.
Mar 24, 2011 | Dryers
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Washer smells bad
Whirlpool and Tide make a cleaner that you put into the washer and run it through a cycle. Front loaders get a build-up that cannot be cleaned by hand. Make sure you are using a detergent that is marked "HE". Do not overfill the detergent or softener cups. I've heard that other used a lot of bleach in a wash cycle to clear out the smell. Bleach is bad to use if you're on a septic system, though.
May 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Feb 01, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Smells of stagnant water
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=2349
Had the solution for me and LG doesn't stink anymore.
Aug 23, 2008 | Dishwashers
Whirlpool front load model#ghw9100lw2 Sour smell in trao
try cleaning pump first ..remove bottom panel and turning pump clean port acess counter clockwiseclean trap thoroughly when cleaning inside try fill with hot water first then pour 1-2 cups CHLORINE bleach into water allow to mix open door and with rag soaked in solution of the bleach water pull door seal back at bottom and wash out as much as possible..to stay ahead of problem try this every couple of months
Aug 08, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool Metal Guild Drain Kits DC-BLT-20W ; DC BLT 20W Bath and Bar Drain with Lift Logo
85 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
