Question about Whirlpool 2 Person Corner Air Tub By Vitabath Bathtubs
Is a 300 watt blower sufficient for a 72"x36" air tub?
I'm shopping for an air tub for our new bathroom addition. Even in expensive tubs I've noticed a range from 300-800 watt motors on the air blowers. Is more better?
  • 125 Answers
The blower should be matched to the number of holes and diameter of the hole. there is a pretty precise science to the whole Air Tub product. if the blower is too large it will burn up and if it is too small you won't get the true benefits that an Air Tub offers.
Posted on Feb 24, 2009
Where can I find a push button starter switch for a whirlpool tub?
A plumbing shop .Speak to a maneger ,they should be abel to ogenize it. They have sertenly helpt me over the years with some weard things.
And be sure to tell them only the button. maby they will even give u a substetute
Jul 17, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
I have a brand new walk-in tub with whirlpool and air jet. It has air switches for both features. My problem is that the air pump comes on all by itself after sitting for 20-30 minutes of non use. It does...
This is known as the purge cycle, it is very normal. It is to blow out any remaining water from the air jets. If it was to allow water to stand in the pipes, it would start to smell and grow algae, which would then clog the small air holes, nothing to be alarmed about.
Mar 12, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
Jacuzzi outdoor bath tub i have there is power but the bubbles thing isnt working
Find the plug for the pump and plug it in ( tub full of water), if the pump works,the problem is in the contol box or switch. if the pump/motor has a plastic tube coming out of a black box, and the pump still does not work when plugged in, it is most likely the air switch connected to that plastic tube on the pump. the switch is avaliable online and not to hard to replace if you are mechanically inclined.
Sep 26, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Mar 24, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Jan 17, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Whirlpool 2 Person Corner Air Tub By Vitabath  Bathtubs Logo
150 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
