Question about VillaWare 5787 Double Smoothee Work Top Blender
Need Dispenser Nozzles for both carafes
The nozzles on each of the dual containers leak and the handle of the didspeser nozzles are broken. Where can I buy replacements?
I just spoke with VillaWare (877-777-8042) and they seem to be in a product line restructure mode now (May, 2009). They do not have any carafes at all right now. Their recommendation is to search online or wait for their restructuring period to end in hopes they might have something at that time. No time estimations were offered.
I do have a single dispenser nozzle that I could post on eBay or sell directly, for what it is worth. If you have questions, contact me at trenten at gmail dot com.
Posted on May 21, 2009
Why is kitchenaid blender making loud grinding sound, only with carafe in place?
If there is no noise without the beaker it will not be the motor. The problem is in the shaft & bush that holds the chopping blade. Dismantle, clean & lube it. If that does not fix it replacement of the assemble is the only other solution
Jun 08, 2014 | KitchenAid Blenders
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
The handle to the pour spout on the bottom of the blender has broken off. So I can not put smoothee in my glass. I have to pour it in my glass for the top of cannister. Where can I get replacement parts?
If any body needs any parts for the villaware 5785 series I have everything available except the plastic smoothee container. I have the smoothee spout. If you need it I can send it to you and you can just reimburse me for the shipping after I have sent it to you. You can contact me at amylovescats2010@yahoo.com. Villaware is no longer selling the smoothee container, I doubt if they are selling other parts for it.
Oct 16, 2009 | VillaWare 5785 Smoothee Bar Work Top...
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Nov 10, 2008 | Maximatic EBL-1000 Elite Cuisine 10 Speed...
New part for VillaWare blender
MANUFACTURER WEB SITE IN MALAYSIA I HAVE ASKED THEM IF I CAN BUY SOME I WILL LET YOU KNOW IF THE PRICE IS NOT TO EXPENSIVE
http://www.alibaba.com/product-free/100075597/Villaware_Moderno_Pro_Infinity.html
Jul 12, 2008 | VillaWare V00143100 Blender
VillaWare 5787 Double Smoothee Work Top Blender Logo
93 people viewed this question
Top VillaWare Blenders Experts
Steve
Andrew Taylor
Andrew Taylor
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
