Question about Simplicity Celebrity S210 Mechanical Sewing Machine
The drop down pressure foot
I orderd what I thought was the pressure foot and wheen it got here it is the wrong part I have a simplicity celebrity S210.
I need help in getting the right part.
Thank You,
Robbie Penney
Reference number on what I ordered is 0238347-1 and it came from TACONY Corp. 1760 Gilsinn Lane Fenton, Mo.
  • 65 Answers
You have to contact Tacony.
Posted on Jan 08, 2009
Where do I put oil
Oil is placed where there are two pieces of metal rubbing together.
1. You must look for moving parts while moving the hand wheel. 2. There are some holes on the frame to give you access areas that need to be oiled..
3. The bobbin rides on an indented area called the race. Place one drop at this location frequently.
4. The motion of the needle arm going up and down between two holes needs to be oiled.
5. The pressure foot has a movement of a steel tube (arm) that needs oiled every now and then. The up and down motion of the pressure foot switch has two pieces of steel rubbing together in order to raise and lower the foot. It is important to oil here and on the spring that is inside the tube.
Anyway; make sure you look for steel against steel and oil it.
Jun 28, 2016 | Sewing Machines
Not feeding material.
Tension generally does not affect the feed unless it is way too tight. Most reasons for fabric not advancing under the presser foot is that the feed dogs have been dropped for darning. If the feed dogs are operating properly, as the handwheel turns the feed dogs should rise above the plate, move toward the back of the machine pulling the fabric, drop down, come forward and rise again.
The other possibility is that the presser foot pressure has been released so the presser foot is not holding the fabric down on the feed dogs. Some machines have a spring-loaded knob on the top of the machine, a dial, or something to adjust the amount of pressure the foot applies. Consult your owner's manual.
Aug 10, 2015 | Sewing Machines
Elna Envision 8007 feed dogs dropped and can't get get them to go back up ...the switch doesn't make a difference. Had this problem before and thought it was fixed. This is the first time I needed to...
Have you actually starting stitching a seam after sliding the feed dog control back to normal position?
In most cases, the feed dogs don't magically pop up until the machine has moved through a stitch sequence.
Put a piece of fabric under the pressure foot, lower the pressure foot, then turn the flywheel towards you two or three turns or use the needle up, needle down control button to make a couple of stitches - this should get them back.
Apr 15, 2011 | Elna 8007
Manual for simplicity celebrity s210
You can buy one here:
http://www.mastersewusa.com/info_simplicity_s210.html
or here:
http://www.sewingpartsonline.com/instruction-manual-simplicity-s210.aspx
Jan 21, 2011 | Simplicity Celebrity S210 Mechanical...
I have a Simplicity Denim Expert sewing machine it's about 5 or six years old but an excellent machine I need to know how to put the foot that holds down the material back on the long iron piece that...
Hi. I believe your machine has a snap-on pressure foot. I've posted pictures of snap-on pressure feet at www.robbiesews.blogspot.com; just look for the 'pressure foot' tag or search the site for pressure feet and you shouldn't have any problem finding that post.
Anyway, there is an adapter (called an 'ankle') at the end of the 'long iron piece that lowers and raises the foot' (excellent description, BTW). The ankle attaches to that piece with a small thumb screw. With the ankle in place, you just lower the ankle onto the catch on the pressure foot.
You can also use regular low-shank feet on your machine. First, remove the ankle. The regular low-shank feet will attach to the raiser bar with that same thumb screw that holds the ankle in place.
You really should get a replacement manual for your machine. I found manuals for Simplicity sewing machines at http://www.sewingpartsonline.com/simplicity-sewing-machine-instruction-manuals.aspx.
Hope this helps!
Robbie
Aug 10, 2010 | Simplicity Sewing Machines
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
Empisal - celebrity 550
what causes ma machine to have loops under the fabric after sewing for about 30 min and it keeps on loosing stiches even after servicing
Dec 22, 2008 | Simplicity Celebrity S210 Mechanical...
Where to purchase pressure foot (same one that comes on machine when purchased
If you go to the Simplicity Homecare website and click on Accessories, that will take you to their e-store for parts. I broke an upper looper needle on my SW432 last Saturday, ordered on Wednesday, and already have the replacement!
Aug 28, 2008 | Simplicity Serge Pro SW432 Mechanical...
Simplicity Celebrity S210 Mechanical Sewing Machine Logo
60 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
