Question about Quartet gbc ShredMaster 950S Strip-Cut Shredder
Gbc shredmaster 950s won't go forward or reverse
I was off work a couple of days. When I returned the bin had been emptied, the bag frame put in backwards and paper was jammed. The top hinge on the cabinet door was broken. I unjammed the paper (included was a large label with sticky back), fixed the frame with bag. The door can be lifted a bit to make the magnet connection. The light goes on but does not go forward or reverse. The sensor plate that goes up when the bag is full seems to work fine. What else can I check for? (except new employees) Thanks!
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Seeking online owners manual for GBC Shredmaster 2260x
Posted on Jun 03, 2010
  • 215 Answers
SOURCE: I have a GBC Shredmaster 2260X. The light on top
most GBX shredders have a magnetic "reed" type switch inside the shredder head that is actuated by a magnet on your door. have you recently lost the magnetic catch on your door? if you have lost it and have access to a strong magnet, you should be able to open door and move magnet around on front side of shredder head and see the light go out. if magnetic catch is on door, then perhaps your door is misaligned in such a way as to not energize the switch.
good luck,
Posted on Jan 10, 2011
  • 8404 Answers
SOURCE: gbc shredmaster 5550x: this machine
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now. is not a parts or repair depot.
Thanks for your question today at
Posted on Jan 27, 2011
SOURCE: GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
Posted on Oct 22, 2011
One of the clips which hold door close broke. thus, machine won't operate.
Does the door fully closing operate a safety switch? If so you might be able to get round this by clamping the door shut with(eg)a belt. Not the most elegant of solutions but it might work. I searched online and got a number of hits, one of which said that spares are not available. Not very encouraging! Try contacting manufacturer directly.
Jun 29, 2015 | Quartet gbc ShredMaster 950S Strip-Cut...
What gallon bags does shredmaster 1256S use?
GBC Shredmaster Personal Shredder Bags Staples i use the plastic bags you get when grocery shopping they don't look pretty but they work for me
Jan 08, 2015 | Shredder Office Equipment & Supplies
It is very noisy
if it is noisy, you have to open the shredder and check the gears if still ok.
if they are worn up they will make the noise
Oct 19, 2014 | Quartet gbc ShredMaster 950S Strip-Cut...
GBC shredmaster 1150x shredder now runs only in reverse. And when I press the "reverse" button, the green "forward/shred" light comes on, rather than the red "reverse" light....
The first thing that comes to mind is that the switch is faulty and that one of the contacts has come loose and is shorting across the reverse contacts. There is little else that can go wrong with a shredder, so in this case try replacing the switch.
Jan 26, 2011 | Quartet gbc 1150X Shredder
My shredder is stuck in reverse. How do I get it to go forward?
Unplug, open and remove all partly shreded paper fron the underside, then try it again. If it is hot to the touch, let it cool for about 15 minutes before trying it again.
Dec 19, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Plactic drive gears
Good luck, Tom
Apr 30, 2008 | Quartet gbc ShredMaster 950S Strip-Cut...
Quartet gbc ShredMaster 950S Strip-Cut Shredder Logo
107 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
