Question about Electrical Supplies
Wire a ceiling light
Ive got 2 black wires and 1 green and yellow wire
    Problem Solver:
  • 19 Answers
Is your house older, Some old wires its hard to tell which one is the grounded conductor(nuetral), Both Look black. If this is case You need to test it with a voltage tester- The green and yellow is a ground wire. Test the green with the voltage tester, Along with one of the blacks, if the Black and green set of the voltage tester that black is the hot. hook it up to the black on the lt. hook white to the other black. and green to either green screew or ground wire which ever is provided
Posted on Jan 08, 2009
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Jun 30, 2009 | Dryers
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Trying 2 wire a ceiling light
Jan 07, 2009 | Solar 2-wire Pull Chain Light Switch For...
Ceiling fan wires
is the old fixture still installed?
Oct 16, 2008 | Hampton Bay 24002 Ceiling Fan
Electrical Supplies Logo
189 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
