Question about Quartet gbc ShredMaster 950S Strip-Cut Shredder
GBC Shredmaster 950s.light is on, no jam, does not go f or revers
I was off work for a couple of days. When I returned I saw that someone had emptied the Shredmaster 950s. The bag frame was in backwards and the door ajar. Someone had broken the top hinge of the door. I saw that there was some paper jammed...I unjammed it, every bit of paper out. There was a piece of a large shelf tag with a sticky back that was in there. The plate on the bottom that senses the bin is full still seems to work. You can still close the door and make the magnets touch. The light goes on, but does not go forward or reverse. Help!
fellowesrep
  • 102 Answers
SOURCE: Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
SOURCE: GBC Shredmaster 5260X - door is closed by light indicates otherwise
Most shredders use a little lever on the door itself to depress a switch on the shredder cabinet when it's closed. This acts as a secondary on/off switch to allow the motor to work when it's safe to do so.Look inside the cabinet with the door open (usually around the perimeter of the opening, towards the top) for a switched door catch, a "slot" with a metal strip exposed, a little box with a lever jutting out of one end of it, or similar. The "slot" type is used when a door mounted "finger" depresses into the slot upon closing, and the metal strip completes the circuit. Any of these different mechanisms may need to be readjusted, replaced, or usually is just jammed up with bits of loose paper that doesn't allow the switch to close all the way. Hope this helps!
Posted on Oct 18, 2008
t_vinson57
  • 58 Answers
SOURCE: GBC SHREDMASTER 4220S
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Posted on May 27, 2009
FixinFax
  • 3085 Answers
SOURCE: need drive gear replacement for gbc shredmaster 1026s
No spare parts are available.
Posted on Jul 28, 2009
One of the clips which hold door close broke. thus, machine won't operate.
Does the door fully closing operate a safety switch? If so you might be able to get round this by clamping the door shut with(eg)a belt. Not the most elegant of solutions but it might work. I searched online and got a number of hits, one of which said that spares are not available. Not very encouraging! Try contacting manufacturer directly.
Jun 29, 2015 | Quartet gbc ShredMaster 950S Strip-Cut...
Why won't my shredder come on?
Plugged into socket? Paper jam? Bad switch?
Feb 26, 2015 | Swingline GBC ShredMaster GLX2030 Jam Free...
It is very noisy
if it is noisy, you have to open the shredder and check the gears if still ok.
if they are worn up they will make the noise
Oct 19, 2014 | Quartet gbc ShredMaster 950S Strip-Cut...
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
My shredder is stuck in reverse. How do I get it to go forward?
Unplug, open and remove all partly shreded paper fron the underside, then try it again. If it is hot to the touch, let it cool for about 15 minutes before trying it again.
Dec 19, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Gbc shredmaster 4220S just stopped working
Check swich door , if door is open the machie stopped for securyti of the operator . the swich is closed whith the door is closed , good luck
Oct 31, 2008 | Quartet gbc 4220S Shredder
Plactic drive gears
Good luck, Tom
Apr 30, 2008 | Quartet gbc ShredMaster 950S Strip-Cut...
Quartet gbc ShredMaster 950S Strip-Cut Shredder Logo
145 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Pie-man
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
