Question about Microsoft Windows XP Professional
I want to install Windows XP on my IDE 2nd HD
Right now windows is setup with C:\ as my 160gb sata drive, I want to use the sata for games only and make my 2nd IDE hd my boot/data drive... I have data on the IDE that I wish to keep copied from my sata, but my sata can be wiped clean with no issues. What is the proper way to do this so that my sata shows as F:\ and my IDE as C:\ ? both are set as masters one in the sata channel and the other ide channel. Thank you for your time.
  • Chris Hoven
    Chris Hoven Jan 07, 2009
    Great! Thank you so much, I knew it wasn't a seriously difficult
    process I just wanted to be sure I did it right the first time and not
    end up with a system I couldn't boot at all. Cheers and again thank you!
  • Chris Hoven
    Wait sorry that won't work I don't think because winxp is installed on my c: drive (sata) right now, if I backup the data from the IDE onto the sata and then install windows on the ide I think it will still put the boot core files on the c: drive therefor setting up a dual boot but I only want one boot... should I disconnect the sata from my system and install windows on the ide then reconnect the sata transfer what I need and then format the sata? wondering if this process would cause boot errors?
    Scholar:
  • 176 Answers
- sata has no master
- i presume u want the OS on the ide drive, and not just that the ide drive to have "C" assigned to it! So : 1 - U can copy the data form the ide to the sata, and then reinstall the OS on the ide (note: the OS will start up a bit slower do to the slower ide drive !!!) and so it will become the C drive ! And u can assign to the sata what ever letter u wish...
2- if u don't want to reinstall the os u can do a copy of the os and put it on the ide drive(not just copy the files !! it will not work!!!). U cold use clonezilla for example... But probably the first method wold be safer ....
Posted on Jan 07, 2009
  • Cisf Jan 07, 2009
    when u;ll install the OS, it will ask u where to install it ! U will chose the drive u want (the ide) and the partition u want on it (if there are more than one ...)
    U can also remove the sata and do the install without it ! (if by chance (very rarely ) when u remount the sata drive the os from it will boot, remove it and remount it again, or do a restart, and the one on ide will boot... than u can delete the old os and have mo more possible issues)
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
I have replaced the hard drive on my HP G5000 laptop with a Samsung HM161GI drive. All tests OK on BIOS diagnostics, but Windows XP Setup says no hard disk is installed??
This happens because the hard disk is natively a SATA and XP doesn't have a generic SATA driver so from its point of view the disk is not there. You will need to go into the BIOS and set the SATA connection to use the legacy/IDE mode.
May 16, 2011 | Samsung Spinpoint M7E HM161GI 160GB 5400...
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Cant play certain games in my sata hd 160gb.
I suppose Hardisk has no problem if its sata or IDE ,games will mostly be Graphics and Processor oriented and also to do with the RAM. Should be some other problem . give me more specific problem you face.
Dec 20, 2008 | Microsoft Windows XP Home Edition
Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Recognize sata hd
No drivers are needed - it should have been seen right away. Check the BIOS to see the drive is seen in the drives tables, and if there, XP needs to have the drive setup using FDISK. The drive will not show under windows until a drive table is on it.
Sep 05, 2008 | Intel Motherboard
Asus m2n-mx se plus windows xp wont boot
All you need is the hard drive manufacture's setup software. Flashing you're bios is not the answer. On each drive (SATA & IDE) is the name & model number. Go to the Mf's site & download the free setup software, tools & utilities. Most sites will list software you can download to creat a bootable floppy disk or software to creat a bootable CD. Run the software on the SATA drive. Than unplug the SATA data cable & connect one IDE at a time. Again down load the Mfg's setup software. Do the same for the other IDE. Disconnect the data cable for the IDE drives. Do a fresh install of windows. (DO not allow windows to format the drive)! Just install windows & the motherboard drivers. Than update windows. Durring reboot press & hold the power on button on the PC untill it powers off. Connect the two IDE drives. Check the pin settings on the IDE drives. Set AS; Primary IDE drive 1 as master with a slave. Set IDE two as a slave drive.
Check the bios Boot setting. Make sure the SATA drive is listed in the boot order. Save & exit the PC. Windows should boot just fine.
Good Luck!
Still have an issue, post the trouble here with a description.
Mike
Jun 27, 2008 | ASUS M2N-MX Motherboard
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Microsoft Windows XP Professional Logo
99 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
