Question about Reddy Heater-30-55,000 BTU Variable
Unit will not run
Its gitting fule and flam but fan shuts off thats all it will do can someone help me out
Sounds like the pump pressure needs adjustment. If it's off from spec, (even a fraction), the unit will not fire up and run. If you still have your owners manual, check to see what the pump pressure is posted for. (probably around 3.5 PSI). Also, check for clogged fuel filter a that will restrict fuel flow and pressure...
Posted on Jan 10, 2009
I have a ruud silhouette gas furnace and I have change everything out and it still won't stay on.
From the description I see try the following.
Take your induction fan blower off and check the condition of the blower wheel. If your induction fan is not pulling flue gas out properly, the flue gas will cause a rollout flame shutdown. Older units induction fan blower wheel rust out and will fall apart and eventually self destruct.
Hope this helped.
Nov 04, 2014 | Heating & Cooling
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
Why won't the fan motor shut off on my 1991 acura legend?
Hey chandralebea,
Try first by replacing the cooling fan engine temp sensor switch, as this may be the cause.
Good Luck
Jul 29, 2012 | 1991 Acura Legend
My 96 ford taurus is having trouble starting after sits for a while but after i get it going it i can shut it off and start it up right away but when it sits for couple hours it acts like theres no fuel at...
the fule is running back to the fule tank when the engine is not running,,,look around for a "one way fule pipe velve" and fit it in the fule line close to the engine,,,that will put a stop to that,,,
Aug 14, 2010 | Ford Taurus Cars & Trucks
A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Jun 28, 2009 | Heating & Cooling
Car just shuts off, then restarts no problem
Run a fule system cleaner through ur car it goe into the gas tanks lol make sure u do it one a full tank if u are able to drive it that much
then when the tank is empty replace your fule filter its on the passenger side of the car mounted on the fram under neith the car..
im thinkin this will solve the problem for sure
the reason u wanna run he cleaner through it first is cause the old fule filter will catch all the nasty **** that hasnt already cloged your fule filter in the first place then u can take it off and pop on a new one.. remember to change your fule filter every 12,000 miles most ppl have never changed the one that was on the car when they bought it.
Jan 04, 2009 | 1996 Lincoln Continental
Car wont stay running even at a idle
It sounds like your alternator is almost done. Thats power distribution right there. If your alternator doesnt work, your car will run for a minute or two on battery power. Then it will kill the battery. If your car starts, its not the injection system, but you might need fuel injector cleaner to just run through your fuel injection system. To check the alternator, get someone to jump your car. leave the cables connected for about five minutes letting the car run. If it still dies, you need to clean your fuel injection system. If it doesnt die, its your alternator. A alternator costs about a hundred bucks.
Nov 30, 2008 | 1990 Dodge Spirit
Reddy Heater-30-55,000 BTU Variable Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
