Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My rear tine tiller lurches out of control when I use it
How do I keep it from lurching forward on new ground or uneven ground?
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Posted on Mar 07, 2009
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
1980 pony rear tine tiller: when I put it into gear it just sits there and will suddenly lurch ahead uncontrollably.
That will happen when the tines are engaged while the wheels are in Neutral as the tines simply drive the whole machine forward without the drag of the wheels being in gear. If the wheel transmission is engaged and this is still happening, then you have need for repair.
farmerbear at FixYa.com
Sep 22, 2010 | Troy-Bilt Pony Garden Tiller
My troybilt lurches forward and you can't hold onto it. I bought it used and the belt was slipping but no lurching problem- After the shop put on the new belt. It lurches forward when you start to...
This is normal for these. The belt slipping before absorbed this. The only real way to prevent this is to weigh the tiller down with large rocks, concrete blocks, something of that sort. They have been built much lighter since Troy-Bilt was bought by MTD, and don't weigh enough to keep from picking up and taking off when you use it. I have a small one, and I weigh it down with about 150 lbs of concrete and lead, and that does it.
May 28, 2010 | Garden
Troy bult junior has new tines , runs to fast...
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
May 19, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My tiller does not seem to be cutting deep enough
Hi there kimberly,
Here's what you need to do.
  • Make sure the depth stake (behind the tines) is up as high as it will go. This will allow the tines to go deeper.
  • Fire it up. Set the tine rotation to reverse (more mixing and twisting.
  • Make sure the tines are actually turning, Each side is held in place with a shear pin. In case something binds the blades, this pin breaking will save the drive train
  • Note how the tiller is balanced. Wheels in the middle. You can tilt it forwards or backwards.
  • Tilting forward allows the wheels to gain traction and move the unit forward
  • Tilting Backwards allows the tines to dig in. If the surface is too hard, Press down with your body weight. It will dig through.
I hope this work out for ya
Best regards
Mike
Apr 25, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My car keeps lurching forward and cutting out when
try looking for an airleak in the hose from the inlet manifold to the brake reservoir,
Feb 25, 2010 | 1998 Volkswagen Golf
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
I bought my troybilt rear tine used. When I use it to till new ground (sod) it cuts fine for a few feet, then without warning, it gets on top of the ground, and I can't do anything to make it cut. The...
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Mar 31, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Crt or srt tiller?
* CRT or SRT -- These are two terms you will see on rear-tine tillers only. o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground. o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Aug 27, 2008 | Mantis Electric Mini Tiller/Cultivator
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
452 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
