Question about Hitachi 43UWX10B 43" Rear Projection Television
Blue droopy line in middle of tv, everything yellowish above
I think my problem is similar to many I've read on here. I'd like to fix it myself if possible as the repairman quoted me $300 and this seems like a lot. I have a Hitachi Ultravision Digital Projection TV. There is a droopy blue line running from one corner of the tv to the other, that falls to the middle of the screen. Everything above that line has a very yellowish cast. Also get some doubled images.
  • bevremax Jan 12, 2009
    I have the same problem and have called a repair company. How much should the repair reasonably cost?
  • panzerak Apr 19, 2009
    red ghosts
  • Hitachi Master
  • 5,138 Answers
Your convergence ICs Stk-392-110s Replace Both ICs.If 110s use 180s if 020s use 040s other wise Go by number on ICs .Mat electronics has parts 1-800-628-1118.Thats Cheap for 300.00 if you only have to replace ICs! Check all resistors around ics replace them if burt/read bad.RK42 3.3ohms RK46 1.8 RK50 2.7
RK54 1.5 RK58 3.9 RK62 2.2 ohms.
Posted on Jan 07, 2009
My problem started with a yellowish blotch in the middle of the screen. Now the color keeps chaning so that everything is shades of green. Where can I get an Hitachi optical block myself?
the light engine is most likely the problem or it has dust ball up in it.
check the lamp for discoloration if all looks OK . that could get costly.
if you have never worked on this set you can destroy the set be careful or take it to a shop.
Dec 23, 2010 | Hitachi UltraVision 60V715 TV
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the parts and the CD with instructions.
Jul 16, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a hitachi 53fdx20b and the red and green colors line up fine, but the blue is droopy at the top and doesnt line up elsewhere, any help?? :)
Ur convergence is dead.U know how to solders?Try this website,Tv repair World.com.to buy a convergence kit,replace what in that kit.
Oct 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Feb 28, 2009 | Samsung PCK520R TV
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Televison & Video
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
I have a hitachi ultravision tv m#53sbx10b s#v1g000279 and everything works but there is a blue and somtimes yellow swoosh thing in the top left corner. it like fades throughout the colors? i was hoping...
Your Green CRTs coolant may be congealed giving the green tube a yellowish look it should be a vibrant green. Try changing the coolant in the CRT
May 06, 2008 | Televison & Video
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Hitachi 43UWX10B 43" Rear Projection Television Logo
170 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
