Question about Quantum Fireball Plus AS 60 GB ATA-100 Hard Drive
Cant find operation sysem - Quantum Fireball Plus AS 60 GB ATA-100 Hard Drive
  • 65 Answers
First of all hello
It is maybe one of two possibilities (3 actually with the third one being a corrupted installtion or faulty hard drive)
Solution 1:
1. Check you CMOS settings (at boot up press Delete or F4 or ESC, look around in the menus and see if the Quantum CD drive can be seen over there. If not it is a clear sign that you battery needs changing
Solution 2:
1. Might be that you mbr is corrupted
2. Get hold of your winxp / vista installation CD
3. Boot from CD "press any key when asked to do so"
4. Choose Repair with Command Prompt from the options available
5. Go to the command prompt and type Fixmbr c:
6. You get a set of warning but you should accept and it will fix your mbr
7. Remove CD and reboot your OS should reboot
Solution 3: Corrupted hard drive or installation
1. You will need to check the health of the hard drive to see if its the installation or the drive itself. A sign that the hard drive is faulty might be listening to it and hearing for unusual repetitive hard drive sounds at start up when you try to boot it up this means that the hard drive needs replacing. If there are no sounds then you need to reinstall the OS
2. I suggest you hook the hard drive to another computer and from My computer check the hard drive if its still readable or not if it is and you can copy from it then the hard drive should be ok.
3. Copy the neccessary files
4. Proceed to hook back the hard drive into your pc and reboot with the installtion CD in place
6. From here on you will be required to reformat and reinstall the OS
7. Install all the drivers
8. Install any wanted software (Anti virus and antispyware are a must)
9. You're done
Note if you do not feel so confident about the reinstall seek some guidance from a technician or close friend who can help you out. Make sure that you follow this fixya carefully!
Was very glad to help you!
Best Regards
(PS: Please take some time to rate this solution)
Posted on Jan 07, 2009
  • Alcatrazx
    Alcatrazx Jan 07, 2009
    First of all Hello
    You must check the following things to make sure that the Operating System can be found once more. I am assuming that you were using this and you cannot find the OS anymore.
    Solution 1: Check your CMOS settings
    1. Start your computer
    2. Press del or F4 to enter CMOS setup
    3. Under the main window you should be able to see the HDD autodetection. Here you should be able to see the Quantum Fireball Plus name detected. This is a clear sign that you battery on motherboard is out and you need it changed in order for the missing operating system not to reappear again.
    Solution 2: Faulty Master boot record
    I am also assuming that you are not using multiple operating systems here
    1. Place the installation CD in computer(assuming it is XP)
    2. Boot the computer
    3. Now you should get a "press any key to boot from CD" and you should be able to boot up the Windows XP setup. From here choose Repair or Repair Console with command prompt (depending on your OS) but you should end up in the command prompt
    (If the XP or VIsta CD does not boot go to CMOS settings and make sure that the Boot options are set such that the CD boots first)
    4. in the command prompt type "FixMBR c:" (without the quotes)
    5. You will get a number of warnings. Accept and go ahead. This will fix your OS boot record.
    6. Now reboot your system and it should be ok.
    Hope that this Fixya solves your problem and you get going :)
    PS: Kindly rate this solution and good luck!
Missing operating system
If you are missing the operational sysem it is more than likely a hard drive issue. If you have the installation cd to recover your system try it now, if it fails the hardware is the problem, first remove it and reseat it back in place, if this fails the hard drive will need to be checked for replacement.
Apr 05, 2012 | ASUS Computers & Internet
My up and down keys for the volumn don't work.
look on the manufactures website and reinstall your drivers for your operating sysem....OR if it came with a disk insert the disk and install the correct drivers for your operating system
May 27, 2011 | HP Computers & Internet
Free download hp compaq d530 driver
Welcome to FixYa
If you need drivers for your sysem then you can find it here
Just choose the correct operating system
Hope this helps
May 02, 2011 | Computers & Internet
I have windows xp and when i shoutdown the system it will freeze at shoutdown screen and also freeze in preparing stand by screen
Your operating sysem is corrupted and need to reinstall the operating system. or if you have the system back up file, try to run the back up files to solve the problem.
Dec 29, 2010 | Dell Vostro 1000 Mobile AMD Sempron...
Sound driver lenovo 3000n100
I assume you've checked on the website?
Dec 13, 2010 | Computers & Internet
No driver found on net plz find it
Drivers were found on your manufacturer's official website. It can be found on Google. Ckick on free download drivers. Enter your model number and operating sysem. All drivers are listed there. Download and install in your PC.
Aug 01, 2010 | Computers & Internet
During instaling o/s system has been damp
reinstall the operating system from scratch
Sep 13, 2009 | IBM NetVista PC Desktop
I need the motherboard driver of intel946gz express chipset family can u provide
hey there, go to the following link and put in the operating sysem you are using then download your driver.
Jun 27, 2009 | Computers & Internet
I get a error on my laptop saying windowsroot system 32 curupted but i cant seem to find it i have the system mechanic disc i bought it at staples but i can get it to load to get to be able to type in the...
the sysem 32 dll is part of your registry , that file is missing or damaged the only thing to help you is to tell you to reinstall the windows operating system all over again
all the best with the lap top
Apr 13, 2009 | Computers & Internet
Quantum Fireball Plus AS 60 GB ATA-100 Hard Drive Logo
132 people viewed this question
Top Quantum Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
