Question about Samsung CLX 3160fn All-In-One Printer
CLX-3160FN Paper Jam when there is no paper jam.
  • jfogle Jan 07, 2009
    It keeps trying to pull from the manual feeder and then can't actually do it. A lot of times you cannot even assist by pushing the paper in and it continually says paper jam. you then have to open one of the doors and close it and wait an EXTREMELY long time for the warm up period to end only to cross your fingers and try all over again.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
4 Suggested Answers
  • 192 Answers
SOURCE: paper jam
Probley not but i think you may be able to extend you warantee if they will let you so they can fix the senser or what ever is casing it to do that.
Posted on Jul 07, 2009
SOURCE: I have a clx 3160fn printer and it does not pik up
No I have not yet fixt the problem I have tacken the printer to a repair shop were I hat to pay $50.00 up front they asct me to come at 3 o;clckin the after noon and the talled me there is somesing wrong with softwere and they have order it in from samsung they said the pikup shaft did only half a turn sted a full turn that takes a few days and they will let me know when to pick it up when I have it back I will let you know how things went kip you postet Matt
Posted on Feb 05, 2010
  • 113 Answers
SOURCE: I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
Posted on May 18, 2010
Why will printer not pull paper all the way from paper feed, it only pulls around 2" and then says paper jam?
sounds like the feed tires are dirty try cleaning them or try the bypass feed to see if that helps.
Aug 08, 2014 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
I removed a paper jam from rear of clx-3160fn. Now the rear door will not close all the way. The two plastic tabs on the rails inside seem to be in the way. Everything I have tried to do and move around...
power it off and on again ...but first repeat the operation like you did when you removed the paper jam...it might not be slide back completely ...
when you power it on keep the button pressed to reset ....
also take a good look to the roller to have all in place ...it might be not in place cause you forced the paper out ..or not removed all the paper if it broke in the process ..
Apr 20, 2010 | Samsung CLX 3160fn All-In-One Printer
I get a paper jam every time I try to print, how do I keep printer from getting a paper jam?
There may be a piece of paper or other object in the paper channel. Open the printer up as much as you can and look for a piece of paper. Also, did you change the paper type? Maybe the paper is the problem.
Jan 28, 2010 | Samsung CLX 3160fn All-In-One Printer
Paper jam
Jul 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Samsung CLX 3160fn All-In-One Printer
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
827 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
