I have used Internet many hours, days; without problems. But now, I can not connect anymore. PPP daemon has died = A modem hang up the phone (exit code = 16). Var/log/messages = warning: secret file /etc/ppp/papsecrets has world and/or group access. Please, can u help me to reconnect ?
  • romainc Jan 11, 2009
    Hi hi99ins
    Thanks a lot, a lot for your help. I need it.
    I will try this very soon, It seems very right. Thanks for your explications.
  • Anonymous Jan 12, 2009
    I have use Internet many hours, ec325 on ubuntu7.1. But now, I can not connect.
    My permissions are right, only rw for user. I have done the same for pap-secrets and chap-secrets without results, what can I do ?
    Novelist:
  • 123 Answers
Your password file (papsecrets) has been given access to users outside your login.
This means someone could potentially hack your connection by gaining access to your papsecrets file.
User permissions for papsecrets needs to be reset to you only, and no global/group access should be allowed. Note: it is a hidden file but is in folder /etc/ppp/papsecrets
Restore the original permissions with:
# chmod a-rw /etc/ppp/papsecrets
# chmod u+rw /etc/ppp/papsecrets
Basically your operating system is defending you from sharing your internet passwords with the world.
Posted on Jan 07, 2009
Ppp and dsl lights not showing on modem
its better to reset your modem by pressing the reset button on the back side of your modem for 15 seconds. Then try to connect to the internet
Feb 25, 2010 | Zyxel Prestige 841 (91-004-226010) Modem
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
First use the following command to see if your card is being detected by kernel.
cat /proc/bus/usb/devices
Then you can use the following script for the installation, you can check if this is for your version of Ubuntu.
#!/bin/bash
#This program automates task of setting up connection for Reliance USB Card on Ubuntu Hardy Heron. This program does not come with any warranty whatsoever. Please use it at your own risk.
# Detect Modem
echo "Modem Detected: $(lsusb | grep -i huawei | cut -d" " -f7-)"
# Get Connection Number from User
echo "Enter Your Reliance Data Card Connection Number : "
read connection
echo "Setting up connection with $connection"
#Install Gnome PPP Package
echo "Installing Required Packages.."
sudo apt-get install -y -q gnome-ppp wvdial
#Add entries to /etc/ppp/ppp-secrets and /etc/ppp/chap-secrets
echo "I:Modifying necessary system files to allow dialing with Gnome PPP..."
sudo chmod 666 /etc/ppp/pap-secrets /etc/ppp/chap-secrets
echo "$connection * $connection" >> /etc/ppp/pap-secrets
echo "$connection * $connection" >> /etc/ppp/chap-secrets
sudo chmod 600 /etc/ppp/pap-secrets/etc/ppp/chap-secrets
#Start Gnome PPP
echo "We are all set.... "
echo "Starting Dialer..."
gnome-ppp &
exit 0
Dec 10, 2009 | Computers & Internet
D-Link DSL 200 Modem install. prob.
Use your old P2 to go to the manufacturers site of the new pc and download the drivers for the network adaptor. Copy them onto a usb drive and reinstall on the new pc
Jul 31, 2009 | D-Link DSL 200 (DSL-200) Modem
Unstable internet connection with a DSL2640U
I've heard that the issue can be resolved with a firmware update.
Go here to get it.
http://www.dlink.co.za/dsl-2640u_t.php
Jul 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Not recognized by cable modem
Turn everything off for 2 minutes, cable modem, router and pc.
Turn on modem and wait 2 minutes for the modem to sync to TW.
Turn on router after 2 mins and wait until the router syncs with the modem.
Turn on PC
It sounds like your router lost its connection to the cable modem, which happens from time to time. TW will not help with your router. I worked for a cable co and the router and modem losing sync was the at least 70% of the calls. FYI cable doesn't use DSL,just the phone co.
May 19, 2009 | Zoom X6 Adsl Modem/router Rohs...
Can't connect reliance ec325 on ubuntu7.1
This can be a real challenge.
If you cannot get on, then get the D-Link box as a quick fix.
You may , just may need to open what is called a UDP port for the router, which if you can get in then set the udp port to accept your vonage.
Vonage is pretty rock solid and most boxes have all udp ports open.
You issue is that you are using a PPP and that is a real source of trouble. You have to be able to tweak the incoming router box. Some ISP 's want you to use there phones and will block ports so you cannot do much.
Complain to your internet provider. Make them fix it or replace a box that will allow open communications with the Linksys / vonage box.
e
Jan 12, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Ec325 on ubuntu7.1 can not connect net exit code = 16
check the permissions for /etc/ppp/pap-secrets !!!
it shold be owned by root !!!
owner : root
access : read and write
group: root
access: none
others:
access: none
Jan 07, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Error 734: PPP Link control protocol was terminated
hi dear, if you are facing the error 734 with n82 using nokia pc suite then i think the solution is delete the extra string in phone and modem option which is in control pannel. the path is control pannel>> phone and modem option>> modem>> select N82 USB modem then click on properties>> advanced tab>> Delete the commend. After that delete the modem settings in handset then connect. it works. just try this . . . . .
Nov 27, 2008 | Microsoft Windows Vista Home Premium with...
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
