Question about Nikon COOLPIX Cameras
Lens error/system error
The camera fell on a ledge at the airport, crashing to the ground. The lens was stuck in the out position and the camera said lens error. I was able to get the lens back in, but the little cover never closed and now it gives a system error and the lens won't extend out. It just says system error.
  • 2 more comments
  • Anonymous Nov 04, 2007
    The lens got stuck in the out position and won't go back in...The screens displays "ERROR 3" which we have no idea what that means.
  • janieliz Dec 04, 2007
    The lens has just stayed in the extended out position. It hasn't been droped or mishandled. The screen says 'lens error!' I've re-charged battery it worked for a bit then the same happened again. I tried re-charging it again but this tinme no luck. Any solutions anyone?
    Janie
  • Anonymous Apr 15, 2008
    SAME PROBLEM
  • nedved53 Jul 31, 2008
    Lens Error
  • Nikon Master
  • 4,738 Answers
The following blog outlines some other repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
    Scholar:
  • 97 Answers
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
Posted on Nov 09, 2007
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
My lens is stuck half way out.
try Googling "E18" and read about this error signal and the many possible fixes. In your case sometimes gentle (really gentle) inward pressure on the lens tube while turning camera on (or off) will get it going again. Best wishes
Mar 04, 2009 | Canon PowerShot A530 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
Canon powershot SD600
Looks like the lens is "out of alignment". Canon charges heftily for this repair. However if the lens is not broken then many people have got it working through systematic bashing. Click here to view the thread
Jul 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
Lens is stuck and will not power on
Hi ive got a solution to this
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
Nov 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Cameras Logo
291 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
